Completed 460 swap:
Old Jan 6, 2002 | 08:20 PM
79Supercab's Avatar
79Supercab
Completed 460 swap:
Well I just completed swapping in a 460 in place of my 400 on my '78 F250 SC 4x4. Took me about three full days. But, I had a lot of time prior to starting in gathering all the right stuff. I read a lot of posts on this site plus the "460 swap" article on the "project Bronco" site. And I think there was still some info missing concerning the PS & Alternator bracketry.
Everything went as I read in all the posts except for the PS & Alternator brackets. I was not able to find a donor 460 van for the brackets, so I used the PS/AC bracket off of a early ‘70s LTD. It's the big honkin' cast piece with the plate on the front. I had to rotate the entire bracket assembly up a little so the AC adjuster part of the front plate would clear my PS gear.
The low mount alternator interfered with my crossmember. I've heard of others cutting out part of the crossmember to allow room for the alternator, but then it would be a bear to change/adjust the belt. So I moved the alternator up on the head as far as possible and only had to fabricate one bracket. I used the front pulley groove for my Alternator.
If anyone else is thinking about a swap (their first time...) in a '78 or '79 Bronco or 4x4 Truck and if you need any help with the brackets, email me as I can explain how I got it all to bolt up and send pictures if you need them....
Ryan.
78 F250 Ranger XLT Supercab 4x4
460, C6, NP205, D44, D60, 4.10's, 33x12.50x16.5 tires
71 Bronco, 302, C4, PS, PDB (1/2 complete with rebuild)
Old Jan 7, 2002 | 07:16 AM
BOSS302's Avatar
BOSS302
Completed 460 swap:
mositso
Engine Swaps
13
Mar 7, 2010 07:30 PM
olered78
Nov 5, 2002 08:44 PM
79Supercab
Dec 25, 2001 11:25 AM
idahocrewcab
Nov 21, 2000 08:23 AM
