Carter YFA fuel return?
Old Dec 13, 2005 | 02:52 PM
little_mule's Avatar
little_mule
On my Carter YFA non-feedback carburetor I have the fuel inlet and adjacent to it to the right, also on the bowl is another fitting of the same size and type. Is this a fuel return line or what? It runs great with it capped but I would feel better with a hose run to the ground (it already had one fire)unless there is another good use for this fitting. Thanks
Old Dec 17, 2005 | 05:30 AM
little_mule
Any takers?
Old Dec 17, 2005 | 03:34 PM
Ford_Six's Avatar
Ford_Six
Sorry, I don't have a YFA or access to one right now- any chance you can put up a picture of it?
Old Dec 23, 2005 | 12:16 PM
little_mule
Picture in gallery now
I put a picture in my gallery of the carb. If I plug the left hand (fuel?) inlet, the idle speeds up very slightly but has little or no vacuum. If I put vacuum to it the engine stops flat. It runs fine plugged but it doesn't seem to have the bottom end torque that I would expect.
It really picks up and goes over about ten mph though. If I rev the throttle and slip the clutch I can break the wheels loose but then it bogs down. Feels like it's just geared too high but I don't know having nothing to compare it too. I also would like to know the purpose of the hole with vacuum at the base of the electric choke. I have it plugged and again, it runs fine, just curious what it was for though. I can find several diagrams but none show anything usefull, neither does the Haynes or Chiltons manual. Any help would be greatly appreciated!
Old Dec 23, 2005 | 09:36 PM
Ford_Six's Avatar
Ford_Six
That right side fitting looks like an emissions bowl vent, would have gone to a charcoal canister on the frame. It's fine capped.
That vacuum source at the choke would be for a heated choke, with two lines going down to the exhaust manifold. It draws air from inside the air cleaner, through a coil inside the exhaust, up into the choke, and then into the carb and intake. If you have a full electric choke and it's pulling off properly, that should be fine plugged also.
Old Dec 24, 2005 | 06:10 AM
little_mule
Thank ya kindly!
That helps a lot.
rustoleum82
Feb 11, 2015 01:14 PM
The Terrible Blob
Oct 4, 2014 11:42 AM
1984Ford300six
19
Aug 29, 2014 12:12 PM
evan.kelly978
Apr 19, 2012 10:41 AM
evan.kelly978
Apr 17, 2012 08:52 PM
