Fuel Pump & ECC Relay
Old Dec 13, 2005 | 01:52 PM
lotic's Avatar
lotic
99 Ford Explorer V6 4.0L OHV
Question. I was looking at some of the threads in regards to cold start or hard start when car is warm.
Everyonce in awhile I have the issue where the car starts up fine after sitting overnight and then I drive to work and let sit for 4 hours or so until lunch time and when I try to start it, it may crank 1-2 seconds before starting ( when originally it fires right up when I turn the key ).
I have 103,000 miles, so maybe age has something to do with. I did have a New Fuel Pump from the dealer replaced a couple of months ago, because at that time it was hard starting all the time, especially after it would sit all night. After I got the new Fuel Pump at the Ford Dealer I had no problems until about a week ago when it started to take 1-2 seconds to start.
If I replace the Fuel Pump Relay or the ECC Relay, will that help? Is that easy to change? What does either of those items do?
Old Dec 14, 2005 | 12:14 AM
srercrcr's Avatar
srercrcr
Those are small electrical parts that merely plug in I believe.
They would be readily available at auto parts stores.
I don't think theyre the problem though....if they were defective or not making a good electrical connection, you'd have a no-start situation, not start after 2 seconds.
There have been some posts, including mine, referring to a once in a great while "cranks fine - no start" situation, followed by an instart start five minutes later.
Different people have replaced relays, moved wires at connections, all to varying success.
dakota-boy
Electrical Systems/Wiring
Mar 14, 2016 09:29 AM
wesley78
Feb 5, 2016 12:16 AM
leefarmfixer
30
Dec 28, 2015 08:13 PM
gehman22
Nov 14, 2006 12:02 PM
onebit
May 30, 2002 01:13 AM
