Fuel Injection pulse
Old May 27, 2002 | 09:28 PM
onebit's Avatar
onebit
Post Fuel Injection pulse
Have a 1988 f-150 w 351 EFI
Has spark and will start with starting fluid but is not getting gas.
Fuel pump replaced and getting pressure in the injector gas rail.
ECC and fuel pump relays ok.
Have 12v on injectors but no injector pulse when cracking.
What causes injectors to pulse??
Old May 28, 2002 | 09:53 PM
topo4u2's Avatar
topo4u2
It sounds like a bad ECM under dash. Pulse signal originates from it and likely the trouble. Wiring can be at fault but not as likely in your case. Try and get one from a local wreckers if they have one. A good shop can test this system out but a fairly substantial charge will be involved. Ford calls it a "breakout box."
Old May 30, 2002 | 01:13 AM
trinogt's Avatar
trinogt
59203shop
61
Sep 16, 2019 03:02 PM
Robert Fisk
31
Nov 26, 2016 04:56 PM
donovan1234
24
Oct 3, 2016 08:33 AM
1990hranger
1983 - 2012 Ranger & B-Series
Jul 1, 2007 01:06 AM
patho44
Feb 23, 2007 02:12 AM
