Explorer door lock trouble
Old Dec 5, 2005 | 03:51 PM
zsomeone's Avatar
zsomeone
I have a 99 Explorer Sport with power locks. A while back, the outside driver's side handle became loose, and it is impossible to unlock it from outside. (If unlocked, it opens fine.) If I must lock it, I have to get in from the passenger side. To get out, I have to simultaneously push the unlock botton and pull the door handle about 5-8 times.
I have torn down the door panel, access is bad and visibility is nonexistant. There is what feels like a plastic ring with wire attached to it moving around on the back of the door handle. I assume this is the problem, but don't know what to do. I can't figure out how to remove the door handle to get a look, it doesn't seem to be attached with screws.
My situation is getting critical, the rod from the inside handle to the door mechanism is bending from the effort of forceful unlocking. If I don't fix it (or get it fixed) soon, I may no longer be able to open the door at all.
The lock actualle works sometimes when the door panel is off, but I can't leave it off because of the power wires. I'd hate to put it in the shop for this, can anybody help me out?
Old Dec 5, 2005 | 05:46 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Dec 5, 2005 | 08:14 PM
jonm61's Avatar
jonm61
I've done some work inside doors and I can't help you with your specific problem except to highly recommend that you let the experts do it. It's so easy to screw up stuff inside the door and then you just end up paying them that much more anyway.
Old Dec 6, 2005 | 12:39 PM
zsomeone's Avatar
zsomeone
Reading other people's posts, a broken spring seems likely. I really don't have the money to put it in a shop right now if I can avoid it. I guess at some point I'm going to have to tear down both doors to compare.
Please keep comenting here, I can use it.
Old Dec 8, 2005 | 04:31 PM
zsomeone's Avatar
zsomeone
For anybody that might be keeping up with this, yesterday everything was working normally again. Conditions are deteriorating today, once again doesn't unlock with the key. So probably not a spring?
Old Dec 11, 2005 | 11:02 PM
Keato's Avatar
Keato
I had the same problem a year or so ago on my '98 Sport. It got to the point that I finally took it to the dealership. They said on mine i needed to replace the door latch assembly and handle. They estimated just shy of $300 for them to do it or $50 for the parts. Needless to say i just bought the parts, and spent a couple hours replacing it myself. Although I had to drill out the rivets of the old handle. If you read up i'm sure you can do it yourself. It seems that this is a fairly common problem on the sports i've had several friends with the same problem. Good Luck
Old Dec 12, 2005 | 09:56 AM
texan2004's Avatar
texan2004
My suggestion would be to take a trip to the local boneyard, especially if it is a pick and pull type. Find one there and practice getting it out on their door instead of yours. A used one will proably be fine since this doesn'tr appear to be too terribly common of an occurance on these vehicles. Probably only goiong to cost yopu between $5 and $10.00.
Old Dec 12, 2005 | 10:17 AM
z28dug's Avatar
z28dug
I had the same problem on my 99XLT a couple of years ago. I had to have both the latch and door handle replaced. After looking at how tight the space was to work I decided this was one of those jobs that was worth paying someone else to do for me.
Apparently the latch simply wears out. A boneyard replacement might not be much better. This is probably one of those situations where it's worth getting new parts.
Old Dec 12, 2005 | 03:39 PM
zsomeone's Avatar
zsomeone
Hmmm.. practice on juck trucks, I like that idea. We have 2 of those close by, many others in the area. And I suspected the handle is riveted, good to have that confirmed.
However, since it's once again working, I'm going to try to stall through the holidays. Since the door handle still feels loose, I'm going to have to deal with it sooner or later.
Please clarify, by "latch assembly" are you refering to the rods, the latch on the side that keeps the door closed, or what exactly? Just trying to get a clearer picture here. Thanks for all the help so far.
Old Dec 13, 2005 | 04:43 AM
z28dug's Avatar
z28dug
On mine both the latch and handle needed to be replaced. The latch is the part on the lower part of the door that keeps it closed and is held in with I believe 3 screws. The handle is the part that is rivited in.
Old Dec 14, 2005 | 10:06 AM
zsomeone's Avatar
zsomeone
That's what I figured, but wanted to make sure. Why do they rivet these things if they're prone to breaking? It just makes it harder. I don't think manufactuers want you to be able to work on your vehicle nowdays. Old cars are so easy. (Off the subject, sorry.) Anyway, thanks, I'll keep you all posted on further developments, but I plan to try to stall through the holiday if possible.
hivoltj
Mar 9, 2015 12:05 PM
Mocha Joe
Jun 26, 2013 08:28 PM
SunBum
Apr 1, 2013 01:34 PM
kev100
Feb 18, 2011 07:30 PM
renee
Jul 30, 2008 02:51 PM
