front end squeak
Old Dec 12, 2005 | 11:39 PM
mad scientist:p's Avatar
mad scientist:p
front end squeak
i have a 94 question again. its a F-250 (heaviest 3/4 i could get...has a 1 ton rear end from factory = longer than normal studs) 351W 4x4. about a year ago (little less) the front end started to sag. i paid $600 to get it all rebushed and aligned. a few months afterwards, the front end started to squeak every once in a while when i turned. now it does it all the time. i was wondering if anyone has experienced this problem and are there any simple solutions?
Old Dec 13, 2005 | 06:58 AM
SRD4X4's Avatar
SRD4X4
Best guess would be a "dry" balljoint.
Old Dec 13, 2005 | 12:10 PM
mad scientist:p
on both the driver and passenger side? it makes me think that the guys that rebuilt it didnt do a quality job, i just asked because i thought maybe there was another problem. but i will look into it and make sure that everything is lubed up. i just have a feeling thats not it, but i hope it is. thanks
Old Dec 13, 2005 | 05:39 PM
MustangGT221's Avatar
MustangGT221
Think it could be that you lost the little rubber pads between the leaf springs? Without narrowing down where the noise is coming from it might be a hard catch.
FYI, most F-250s came with the "1 ton" rear axle. There were two versions of the F-250, a LD and HD. Same body style (unlike the newer stuff) but the rear axle was either a semi-floating 10.25 or a full floating 10.25 (HD). There was also a D44 or D50 front axle.
The 10.25 full floater is infact the same axle used in the F-350s but most F-250s have it. My dad used to think ford put together a mixed bag of parts on this F-250 because he found out the hard way through parts buying that there are F-250 parts that are the same as the F-350 parts but ford did it on every one of them and not just his.
Old Dec 13, 2005 | 06:09 PM
mad scientist:p
thanks for the info. but as far the leaf spring missing their plastic (or rubber) washer type guides, no they are still there. and the noise seems to be coming from the spindle. like the ball joints or something. i had one of the guys from here say that maybe the ball joints could be dry, but i know that they are not. seems like every 6 months or so we tear apart the front end (well brakes and wheel bearings) and replace it all, and in that process we grease everything. so maybe the ball joints are bad, but they shouldnt be because they are supossed to be new. i guess i'll just have to tear it apart this summer when i get time and redo it all
Old Aug 5, 2006 | 01:47 AM
dktsharpe's Avatar
dktsharpe
Did you ever find your problem? My truck is doing the same thing but I haven't had anything done to it yet. My truck makes noise as I turn sharp into a parking lot that is slightly uphill. Sometimes it makes a popping noise. Thanks for any help.
Keith
Old Aug 5, 2006 | 02:30 PM
fmr9's Avatar
fmr9
This article helped me fix my pops. Real quick and easy and NO money.
http://www.troublecodes.net/articles...d_trucks.shtml
Good Luck Frank
AkF250HD
Aug 7, 2013 06:31 PM
Truck55
1997 - 2003 F150
Jul 29, 2012 08:17 PM
creature84
Mar 9, 2008 10:33 AM
naiku
May 23, 2006 12:20 PM
shaniafan3
1997 - 2003 F150
17
Feb 23, 2004 09:42 PM
