The Cork
Old Dec 16, 2005 | 06:34 PM
  #76
Dungeon_Master's Avatar
Dungeon_Master
Wouldnt the bucket on the drop create a vacume drawing the water upwards towards the outer edges and spilling over the sides in a matter of speaking. in said vacume it would displace the water and the cork would be left where it is.
Old Dec 16, 2005 | 08:18 PM
  #77
Greywolf's Avatar
Greywolf
*BANGS GAVEL*
Next case please...
Old Dec 17, 2005 | 08:46 PM
  #78
jroehl's Avatar
jroehl
Originally Posted by sigma
The original question asks whether the cork will float to the top of the bucket normally, slower than normal, faster than normal, or not at all. It is immaterial whether the cork moves a tenth of a millimeter then stops or never moves at all.
With water of sufficient depth (more than the length of the cork), no, the cork won't make it to the top.
Jason
Old Dec 17, 2005 | 09:03 PM
  #79
jroehl's Avatar
jroehl
Originally Posted by krewat
Variation in density? There is none. And, that's NOT what causes bouyancy.
Ummm...then why would a submarine be crushed at extreme depths of the ocean? Water is denser at the bottom than the top of whatever container it is in. It's true of any fluid, or gas for that matter. That's why the atmosphere gets thinner the farther away from Earth you are. THIS IS THE POINT YOU ARE FAILING TO REALIZE. Restudy your fluid mechanics.
Look at the bucket at rest with water in it. Insert cork. Water level goes up. The amount of water displaced by the cork is what gives the cork bouyancy. Any object that weighs less than the amount of water it displaces will float. Any object that weighs more than the amount of water it displaces sinks.
No disagreements here with that statement. You just described how densities of dissimilar materials causes them to interact.
Since gravity is what is working on the water to produce the bouyancy, as soon as the gravity is gone (or at least, it's effect in free-fall), there is no bouyancy.
Again, due to the density gradient in the water, and the water has mass, it takes time for that gradient to go away once the free-fall starts. In other words, for that gradient to go away, the water has to expand in order to assume a uniform density. Think of it like this: before the drop, the water is like a spring compressed somewhat by its own weight. Since it is compressed, its length is reduced. Put it in free-fall, and it will relax to its natural length. This transition from a compressed state to a relaxed state will take some amount of time.
Never mind, I give up.
I'm a painter by trade, so I've got lots of buckets sitting around. I also like wine and have a camera. Don't make me go there.
Or, I could send all this to an old physics prof of mine....
Old Dec 17, 2005 | 09:17 PM
  #80
jroehl's Avatar
jroehl
Here's a link that explains more about how things float and such...
http://www.school-for-champions.com/...idfloating.htm
Note especially:
"Fluid pressure from gravity At any depth in a fluid, the pressure in all directions is proportional to that depth. Thus, the water pressure at 10 meters is twice the pressure at 5 meters.
An object under the water will have a downward pressure on its top proportional to the depth of its top, and it will have an upward pressure on its bottom, proportional to the depth of the bottom."
The second paragraph explains buoyancy, which does depend on the pressure (and therefore, density) gradient in water. Like I've been saying it will take time for the water to transition from this state (when it's at rest) to a state of equal pressure and density throughout the mass of the water (when it's falling). It is in this time that buoyancy still exists and will cause the cork to rise.
Jason
Old Dec 17, 2005 | 11:15 PM
  #81
krewat's Avatar
krewat
FTE Leadership Emeritus
The water is only "denser" because of "weight" - in free-fall, the water is not "denser" at any level than any other.
Old Dec 18, 2005 | 12:15 AM
  #82
GotLift's Avatar
GotLift
OK geniuses. If your car could travel at the speed of light, would you still need headlights?
Old Dec 18, 2005 | 12:20 AM
  #83
budman-mo's Avatar
budman-mo
I think the real question here is why are you throwing a perfectly good bucket off a building and how much will the fine be when you get caught?
Or how much jail time if it hits someone?
Old Dec 18, 2005 | 12:47 AM
  #84
Greywolf's Avatar
Greywolf
Then fer chrissakes don't drink out of the wrong BUCKET!!!
I'm sure Ivan would agree, come to think of it - I need another bucket of beer...
*ROFL*
79-400-POWER
62
Jul 9, 2007 05:01 PM
Greywolf
26
Aug 26, 2006 12:59 PM
yendor
Jul 3, 2006 08:54 AM
Beast12
May 14, 2006 05:35 PM
sierraben
Jan 8, 2005 12:31 AM
