2004 Explorer Stereo/Back up warning
Old Dec 11, 2005 | 11:19 PM
explorer04's Avatar
explorer04
A few questions for someone who may be able to help...
1. I have a 2004 explorer with a 6-disc in dash factory changer. I am looking to install an ipod adapter, however...i need to know if there is an auxiliary input in the back of the stereo so it can be hardwired.
2. On the same token, my stereo is ready for satelite radio, can i choose xm or serius? will i need to have a seperate display for the satellite radio or can everything be done with the stereo?
3. I have a back-up sensor on my vehicle. When I put the vehicle into reverse it automatically shuts itself off and I cannot turnit back on until I am in drive. Even after when I put it in reverse without shutting off the vehicle it will shut itself off automatically.
An answer to any of these questions will be greatly appreciated
Old Dec 12, 2005 | 06:38 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Dec 12, 2005 | 09:48 AM
texan2004's Avatar
texan2004
1 - Depends on the stereo you have hut yes, I lbelieve there is an auxillary input.
2 - You can choose either XM or sirrus. Some of the Ford stereos are set up for sirrus, again, depend on the steroe you have. I do not beleive that any are set-up for XM. In all likelyhood, you will need a separate display for either unless you have the radio that will operate the sirrus system.
3 - Take it to the dealer. This should be a warranty item.
Old Dec 14, 2005 | 06:37 PM
dyarab's Avatar
dyarab
I have a 2003 Explorer Sport Trac and everything I've seen, which really Edited out by Admin me off, that if you have an in-dash 6-disc changer no adapter will work.
I hope I'm wrong but still searching to no avail yet.
Old Dec 14, 2005 | 10:10 PM
nymets78's Avatar
nymets78
i have an 04 with the 6 cd in dash stereo and I purchased the adapter that allows for sirius radio using the existing radio display. i've had it for 2 years now and am extremely happy with it - no extra displays needed.
Old Dec 15, 2005 | 05:46 AM
dyarab's Avatar
dyarab
I'm referring to iPod integration. I wish it were that easy for the iPods... apparently the in-dash 6 disc changer screws everything up.
Old Dec 15, 2005 | 10:14 PM
Kraut's Avatar
Kraut
1.) No clue
2.) You can enable the "sat" function of your ford factory radio with XM as well, but there IS a potenital caviat.....
There is a Ford XM Kit out there which, via an adaptor cable which "splits" the existing harness to your radio, allows "in dash" XM sat capability. The adaptor harness provides the connectors needed for the receiver unit and the smart adaptor unit, allowing you to splice/plug these into your radio wiring harness.
And, yes, the assoicated alphanumerics of xm sat radio will appear on your radio display, toggled via the "text" toggle button on your radio.
Caution... I tried to install this kit on my '05 Explorer with the Single CD/SAT/MP3 radio head. Ford changed up the harness plug on the back of this radio and the kit would not fit MY RADIO, only because of the harness plugs installed by Ford. IT MAY WORK ON YOURS, THOUGH.
Check out:
http://www.crutchfield.com/S-IU13ePg...=209XMDFDK#Tab
If the link doesn't work, go to crutchfield.com and search on "Ford XM".
BTW, here is MY customer review that appears on Crutchfield:
I'm sure this is a good product---never had the opportunity to find out, though (see below).
This kit has a wiring harness (the large one with the large, rectangular, multi-pin connectors on either end) which is intended to fit in-line with the factory harness, and connect up to the radio head, thus providing the T-d off wires to further connect to the included modulator unit and smart digital adaptor.
Somewhere along the line, ford changed up the ONE connector plug on the back of the factory head unit, such that TWO smaller rectangular pin connectors now plug into the radio head via the factory harness, NOT just the ONE LARGE ONE.
Thus this kit does not fit ALL factory, SAT enabled radio heads. My vehicle ('05 Explorer) came with the Single-CD, SAT enabled, radio --- looks like the 6-CD in-dash changer, but only takes one CD at-a-time.
This kit will NOT work with this particular radio head.
THUS,
I went with the skyfi2 + the vehicle specific mount for the explorer...WORKS GREAT.
BTW, I recommend crutchfield... GREAT service, GREAT Tech support, GREAT price. This kit MAY, INDEED, fit your radio. Check to be sure.
3) Hmmm, sounds like the dash switch may be hosed....didja chack all fuses? Hate to say it, the dealer may be your best bet on this one...
Cheers....
Old Dec 27, 2005 | 08:55 PM
micgang's Avatar
micgang
I have the same reverse sensor issue. Sounds like exactly the same issue. Was yours corrected and if so, what was the fix?
MrManimal
Electrical Systems/Wiring
13
Sep 11, 2014 02:12 PM
O SEA D
May 30, 2010 06:37 PM
pdoug72
May 18, 2010 07:45 AM
swannman
Aug 8, 2007 05:20 PM
bobbyy
Dec 22, 2002 08:04 PM
