goofy stereo issue
Old Jan 28, 2002 | 08:58 AM
bobbyy's Avatar
bobbyy
goofy stereo issue
Does anyone elses factory stereo quit working when they shift from park to reverse and come back on when they put it in drive? Is this some kind of safety feature or is my radio just screwed up? Thanks in advance for any replies. I have a 2000 Expediton. I've read the oweners manual but did'nt find any info.
Old Dec 13, 2002 | 09:05 AM
dirtriderdan's Avatar
dirtriderdan
goofy stereo issue
Old Dec 22, 2002 | 02:56 PM
00EXPY73BRONCO's Avatar
00EXPY73BRONCO
goofy stereo issue
>any info
I am having the same problem with my expidition stereo. I start my truck and the stock system (recently added aftermarket cd changer)
plays fine until I put it into either reverse or drive. Park & neutral it plays fine. Also when driving sometimes the windshield wiper light on the dash & 4x4 light light up and go off. Any ideas ? I can also hear a clicking/or some sort of noise coming from below the steering column area I think. Not sure if the noise is coming from the fuse box or not. Fuse (25amp) is okay. bCould it be the stereo relay, ignition switch, or ?
Old Dec 22, 2002 | 08:04 PM
Racerguy's Avatar
Racerguy
goofy stereo issue
You could have a couple different problems.
I've seen the Transmisison Range Sensor (TRS) cause the radio problem. The TRS is on the side of the transmission where the linkage goes into the trans. It has one connector and 2 screws holding it on. The wiper/4X4 problem could be the 4x4 lockout switch on the transfer case. It is on the driver's side of the transfer case at the front near the top....above the front driveshaft. If you replace the switch also drain and refill the transfer case. Just a bit of moisture in it is enough to cause switch problems.
It could also be a GEM problem. The GEM (generic electronic module) is attached to the back of the fuse box and sometimes will get water in from a windshield leak. The water causes all sorts of problems like you've described. The fuse box can also get water in it causing similar problems.
I would probably start by unplugging the 4x4 lockout switch and see what happens. It's the easiest thing to try. Next you could start the truck in Park with the park brake on, then disconnect the TRS and see what happens.
Or you could just take it to your friendly neighbourhood Ford dealer and have them check the TRS either on their NGS or WDS scanner. They can also check and see what the 4x4 switch is doing when the problem happens and can do some GEM tests too.
mhoefer
Feb 12, 2017 08:18 PM
wrd0225
Aug 27, 2016 02:52 PM
brianjwilson
1983 - 2012 Ranger & B-Series
13
Jul 24, 2013 10:29 AM
haenerhotrod
Mar 19, 2004 04:14 AM
Danex
Feb 28, 2004 10:56 PM
