injection or carb
Old Dec 11, 2005 | 12:53 PM
BIG-COUNTRY's Avatar
BIG-COUNTRY
injection or carb
i am in the process of building my 81 f150 for offroad/street use. i am now looking for a rebuildable 351w motor wich would be easyer to rebuild carb or injection? and wich would be a better for offroad/street carb or injection??
Old Dec 11, 2005 | 02:27 PM
bob arrington's Avatar
bob arrington
carb would be easier to rebuild 'less parts'. the same argument for off road/street use also,bob
Old Dec 11, 2005 | 07:52 PM
The SnoMan's Avatar
The SnoMan
Yes, it easier to tune to engine mods and better WOT power. While FI can have better drivabilty at times and better cold starting it is hard to beat a good carb for maximum WOT power.
Old Dec 11, 2005 | 08:01 PM
BIG-COUNTRY
what does WOT stand for snowman??
Old Dec 11, 2005 | 09:15 PM
LxMan1's Avatar
LxMan1
Wide Open Throttle EFI is a bit more to initially set up, but it will out drive a carb anyday. It's also not effected by the bouncing around of off-roading. Better mileage also.
Old Dec 11, 2005 | 10:19 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
if you have the patience...run efi....better offroad capability, not sensitive to altitude changes....angles, cold starting is easier. on teh street...smoother operation, better economy easier starting etc...
you can never tune a carb as finely as you can efi.....
Old Dec 12, 2005 | 09:21 AM
The SnoMan's Avatar
The SnoMan
Maybe if you do not how to setup and match a carb to your needs. FI might have a edge with MPG but not in max power and throttle responce and reliabilty and simplicity to fix too. A good carb and intake still rules there.
Old Dec 13, 2005 | 09:56 PM
LxMan1's Avatar
LxMan1
I know how to set up a carb, I've been working on race engines for 20 years. You can not mar the fuel curve throughout the entire rpm range with a carb like you can with EFI. The fast Mustangs run EFI due to it's tunability. EFI rarely fails and usually other than a bad fuel pump or maybe an occasional sensor, it's trouble free. My 88 Stang has over 160,000 miles on it and I have never replaced anything in the EFI (including the pump) and it has perfect throttle response and tire shreading WOT power.
Old Dec 14, 2005 | 07:56 PM
Blurry94's Avatar
Blurry94
Another vote for Fuel Injection!
Old Dec 15, 2005 | 01:52 AM
ken's1971's Avatar
ken's1971
Better mileage! just how much would a stock 390 or 300I6 benefit. The cost of one of the holley systems here is 1740. If it does not bring alot of mpg with it, i would say its not worth it.
Old Dec 16, 2005 | 08:53 PM
LxMan1's Avatar
LxMan1
It's all in what you want. I personally prefer EFI. I think that the Ford SEFI EEC IV is one of the better systems out there (Factory)
If it is in your budget, I would go with an EFI unit like Holley, they are very tunable and drivability is great. It probably wouldn't pay for itself in gas mileage for a very long time, but the way that it would run and perform would be noticable.
The stock 300I6 EFi is a good running engine.
Old Dec 17, 2005 | 09:43 PM
dmanlyr's Avatar
dmanlyr
Fuel injection is the only way to go, on or off road. Simply stated, carbs are not dynamicly adjustable for the various conditions (IE air density, altitude or temp) While you can set up a carb to run as well as EFI, it would only be for that EXACT day, with those EXACT conditions.
Horespower for horespower at WOT makes no difference. Either a carb or EFI will deliver the fuel and air needed. It is the rest of the driving range that EFI make sit so much better.
As far as fuel mileage goes, in our marine engines, it has made a verifiable 30% decrease in fuel usage with EFI.
My two cents, David
Old Dec 19, 2005 | 11:07 AM
workingdog's Avatar
workingdog
Anybody out there running FAST or MegaSquirt or TEC3r EFI systems?
Anybody out there running an MSD digital ignition (advance done by computer) setup?
Peter
Old Dec 19, 2005 | 08:46 PM
Ford_Six's Avatar
Ford_Six
I'm ordering the Megasquirt for 390EFI build towards the end of next month, but I won't have that running until late next summer.
Old Dec 20, 2005 | 07:32 AM
Icicle's Avatar
Icicle
Sigh.....
here we go again.
You cannot tune a carb, no matter what your knowledge level may be, to outperform a computer that takes multiple readings, and makes multiple adjustments per second, period.
If your set up with a twEECer or something similar, FI is easy to change too. Dont get me wrong, I prefer the simplicity of a carb, and I enjoy playing with them, but the reliability and performance of fuel injection simply cannot be matched by a carb, at WOT or otherwise. I agree with LXman
