Sponsored by: Real Truck
2000 250SD starting problems (Help Please)
Old Dec 10, 2005 | 08:10 AM
Lafeve's Avatar
Lafeve
I have a 2000 ford 250SD 2WD Automatic with the 5.4 liter V8. Starting approx.1 month ago I started having starting problems. If I let the truck sit for a while (like overnight) and try to start it, it will fire up for half of a second and then die immediatly or sometimes idle really rough. If I start the truck while holding the gas partially down it will start but not want to idle, I have to hold the gas down a little for 10 - 20 seconds then the rpms pick up and it will Idle fine. The real frusterating thing is it is intermittent but does seem to happen more in the cold weather.
I have changed the fuel filter, and tested the fuel pressure but all seems fine. Does anyone know what it could be? Please respond.
Old Dec 10, 2005 | 08:46 AM
99f350sd's Avatar
99f350sd
The IAC or idle air control valve can stick or go bad on these engines. Sounds like you have a bad or dirty one. Its bolted to the throtle body by 2 8mm screws and a connector. Most guy's get a new one, some try to clean it.
Old Dec 10, 2005 | 09:13 AM
dmp437's Avatar
dmp437
Ditto the IAC; it's dirty or trashed. At rest (no one's foot on the pedal) the butterfly in the throttle body is closed. So when you try to start the motor fuel is present via the injectors but no air because of the closed throttle plate. The engine computer opens the IAC the correct amount based on a bunch of ambient parameters and the motor fires right up. When you start the truck by holding the pedal it's now getting air but won't idle because it's the right amount of air; you're either too rich or too lean and the truck idles roughly.
Pull the valve and soak it in carb cleaner and it should clear it up.
Old Dec 10, 2005 | 07:36 PM
Lafeve's Avatar
Lafeve
thanks for all your help!
I pulled off the IAC valve and it was really dirtty. I replaced it with a new one from NAPA ($40). It seems to have fixed it. Thanks for all your help!
Old Dec 10, 2005 | 08:04 PM
99f350sd's Avatar
99f350sd
thanks for gettin back, its nice to know the outcome...
Dick
lindboep
Jul 28, 2014 02:29 PM
sol85
Oct 6, 2010 04:32 PM
seanandnik
Jul 27, 2006 05:36 PM
dpesposito
1978 - 1996 Big Bronco
Feb 15, 2006 04:11 PM
wrpittman2
1983 - 2012 Ranger & B-Series
Jul 27, 2004 04:25 PM
