c6 tranny not shifting when cold
Old Dec 9, 2005 | 09:06 PM
soobad's Avatar
soobad
Cold mornings starting my truck and letting it warm up for about ten minutes but when I pull off it seams like it doesn't want to shift, rpm's go up to 3500 before it shifts then I have to let off the throttle before it shifts, sometimes even if it warmed up the rpms climb before it will shift, then bang it shifts hard…does this make sense?
Old Dec 9, 2005 | 10:05 PM
PLC7.3's Avatar
PLC7.3
How old is the VRV on the IP, when was it last set, are there any vacuum leaks. Is the line to the trans still hooked up......
Old Dec 10, 2005 | 06:47 AM
Lazy K's Avatar
Lazy K
I agree sounds like you have no vacum going to the trans.
Old Dec 10, 2005 | 06:38 PM
soobad's Avatar
soobad
ok i took a stabe at adjusting the little vaccum thingy on the side of the injector pump, think that when i changed the injectors a month ago maybe my big *** moved something, well after making the adjustment it shifts smooth as silk, now what was it that i adjusted? now if i could just get those damn rockers from chattering....
Old Dec 10, 2005 | 07:10 PM
JMac444's Avatar
JMac444
Had the same problem as you, did the ip and injectors, after that she shifted funny could rev her all the way or close to the govener let off the throtle, and shift hard, only in first tho, second and third where a lil wierd but would shift, Problem Vacuum switch on ip, you must replace the vacuum switch when u do the ip and injectors, this is pretty much the timing for for tranny shifting, i put a new vacuum switch on the pump and adjusted the modulator on the tranny, she shifted like a dream after that. I bet thats your problem try it, the switch was $65 bucks if i recall.
Josh
Old Dec 10, 2005 | 10:05 PM
soobad's Avatar
soobad
but why are the rocker arms chattering?
Old Dec 11, 2005 | 06:47 AM
JMac444's Avatar
JMac444
Idk lol, pull the valve covers off and see why they are lose or something, i have never heard that one before, looks like you got some research to do.
alumcanTandThd
Dec 20, 2014 12:16 AM
Bones Digger
20
Jul 9, 2012 01:53 PM
jt371
Jul 27, 2011 08:09 AM
NAMDROF
13
Apr 5, 2011 11:02 PM
Bluedog75
1983 - 2012 Ranger & B-Series
Jul 18, 2010 05:19 PM
