Strange Noise?
Old Dec 9, 2005 | 09:27 AM
seanlleiker's Avatar
seanlleiker
Strange Noise?
Hi everybody, I'm new to the site. I have a '97 F350 crew cab long box 4X4 PSD with the 6637 mod and straight pipe. I don't know much about diesels and you guys have helped solve a few problems I've had in the past. But I have a question about a noise I'm hearing. It is really cold here and this is the only time I have heard the noise. While I'm driving eveything sounds great, it is when I let up on the pedal this hollow noise starts. The exhaust noise sounds like a hollow hissing. When I step on the pedal to give it a little juice the noise goes away and the truck sounds like it always does. I have noticed that the temp. gauge never gets above the cold line. I was hoping someone had an idea what this could be. Thanks
Old Dec 9, 2005 | 09:59 AM
ltfox's Avatar
ltfox
The noise you are hearing is the exhaust back pressure valve. its normal. It closes to help the engine warm up when cold.
Old Dec 9, 2005 | 10:02 AM
wycowboy's Avatar
wycowboy
Does it also sound like the engine sound is getting muffuled a bit?? I ;m thinking you might be hearing the EBPV Exahust back pressuer valve it is just past the turbo outlet and it there to help the engine warm up faster..so thay say.. you can dissconect tha wiers that run to it.. thay are back under the inlet of the turbo drivers side,.. and seeifthat helps.. J
Old Dec 9, 2005 | 10:07 AM
seanlleiker
Thanks Itfox. It has been in the 0 to negative degrees for the last couple of days. It seems that the truck just isn't warming up, even after driving for 30 minutes. Is there anything I can do to help this?
Old Dec 9, 2005 | 10:13 AM
jimkidd's Avatar
jimkidd
Replace the thermostat.
Old Dec 10, 2005 | 10:08 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Welcome to FTE's diesel forums.
It will warm up faster and stay warmer if you block off the radiator. There are a few commercial covers available, but it's cheaper to just use a piece of cardboard.
Like ltfox and wycowboy mentioned, your exhaust backpressure valve seems to be operating normally.
Old Dec 11, 2005 | 08:51 PM
strokr2core's Avatar
strokr2core
I think I've got the same sound as sean does, except it feels like I'm losing a little power at the same time. It happens whether or not it's hot outside just driving around town @ 25 - 30 mph or so. I can throttle through it, but I end up speeding (no ticket yet). It's just really annoying.
Old Dec 11, 2005 | 08:54 PM
strokr2core
btw, this is the best site I've seen for psd's. Thank you for the help and your time guys!
Old Dec 12, 2005 | 08:01 AM
jimkidd's Avatar
jimkidd
Ford Truck Enthusiasts. The first and the best!
I find this group of people a freindly as any. Even if Scott won't call me.
There is always someone that can help you with any problem you have. But there is so much more.
