Power Inverters
Old Dec 9, 2005 | 03:44 AM
karljay's Avatar
karljay
Power Inverters
I need a power inverter to run a PC from the truck & harbor freight has the Chicago electric 2000 watt modified sine wave on sale for $149
Problem is that harbor freight stuff is usually low end.
Anyone use one of these? Are they any good?
Is 2000 watt continuous 4000 peak enough to run a computer and inkjet type printer ?
Thanks, KarlJay
Old Dec 9, 2005 | 06:01 AM
trike1946's Avatar
trike1946
Pep Boys has a 1200 for about $99. Check how much power you need. There should be a tag on the equipment. It should tell you amps. Amps times volts = watts.
Old Dec 9, 2005 | 09:19 PM
b2_tim's Avatar
b2_tim
A 1000 W inverter will easily run a personal computer and monitor. Harbor Freight is scarry, and electronics from them is, buyer be ware. I bought a Statpower, I believe Northern tool sells them, made in Canada, and mine has worked great since 2000, (Y2K). Just try to stay away form electrical stuff made in China and you should be fine.
Old Dec 9, 2005 | 09:28 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
1000 watts should be sufficient - but I'd look for a true sinewave inverter if I'm powering an expensive laptop. Some of the stepped semi-sine wave inverters don't work well with the more sensitive electronics.
Old Dec 9, 2005 | 09:53 PM
ford390gashog's Avatar
ford390gashog
way more than enough. to find the required wattage take the amps of the computer and printer and multiply by 120 my guess is 4 amps total or 480 watts. use a good quality one.
Old Dec 10, 2005 | 12:36 AM
karljay's Avatar
karljay
So the pep boys one is a true sinewave inverter?
Old Dec 10, 2005 | 03:32 AM
karljay's Avatar
karljay
Just checked out some in an ad from PepBoys:
Vector 1200 $99
2000 $199
I'll be running 1 PC (non laptop) w/ 15" flatscreen and 1 old dotmatrix printer and sometimes a NiHm battery charger for flashlight batteries (this is optional)
Most PC's have about 400watt power supply but I doubt they actually USE that much. The printer probably doesn't use more than about 50 watts, but that's just a wild guess.
Do you guys think the 1200 would work?
Is Vector a good brand?
Here's a link that has the specs, but I don't understand 'modified' sinewave output
http://www.donrowe.com/inverters/vector_1200.html
Is 'modified' sinewave good for a PC, should I run a UPS between the PC and the inverter?
Thanks KarlJay
Old Dec 10, 2005 | 11:07 AM
b2_tim's Avatar
b2_tim
Modified sine wave means it is not a true sine wave, ie it is a rough approximation. If you get an inverter with a modified sine wave, don't use a surge protected power strip. The circuits inside will clamp down on the modified sine wave and you will hear clicking and possibly damage the power strip. Use a plane ole extension cord. Most PCs power supplies are filtered enough to give acceptable results. I don't know anything about Vector inverters, but I stand behind my NON CHINA statement above. I have torn into enough of this junk to know.
Old Dec 10, 2005 | 11:49 AM
The SnoMan's Avatar
The SnoMan
I 300 watt inverter will run a computer just fine. No need for over kill here, the bigger the inverter, the more power it draws at partical load. Inverters reach maximum efficency at above peak load so if you wan the most of your battery power going to your load, do not oversize it greatly for your needs. BTW, a 2000 wat invert would draw close to 200 amps at rated load and well beyond that on surges and that is byound the abilty of a single battery to provide with any stabilty in supply voltage
BruteFord
Electrical Systems/Wiring
May 2, 2013 04:50 AM
KingFish FX4
Apr 12, 2008 06:17 PM
Super Steve
Garage & Workshop
Feb 7, 2008 08:49 PM
digger190
20
Oct 3, 2006 06:58 PM
j wright
Ohio Chapter
Nov 28, 2005 07:45 AM
