Sponsored by: Real Truck
power inverter installation
Old Apr 12, 2008 | 01:43 PM
KingFish FX4's Avatar
KingFish FX4
where is the best place to install a 1200 watt power inverter? It will be powering a large chest freezer in bed of the truck on a 3 day 2000 mile trip.
Old Apr 12, 2008 | 02:03 PM
toolman05kr's Avatar
toolman05kr
Behind the rear seat with a weather proof outlet installed in the bed. If you happen to have a cap on the truck, then you can safely install it in the bed of the truck. welcome to fte, you'll enjoy it here.
Old Apr 12, 2008 | 06:17 PM
bullitt55's Avatar
bullitt55
Thumbs up inverter location
I run a 4k watt inverter inside my topped bed. I built a plywood box 12"x12" by 40" long. The inverter and two deep cycle Optimas sit next to each other along the back bed wall. I covered the box with matching bed dr. fabrick. To power/charge the batts I ran a 2awg cable from one of the underhood batts, with an 40 amp fuse, and most important a relay that's closed(working) when the trucks ignition is on. This keeps you from running down the trucks batts. which can happen very quickly when running an inverter. I use my inverter to power a small microwave, and drip coffee pot (at seperate times)while traveling. I hope 1200 watts is enough for a full sized freezer, sound a little small to me....
jazz77
Dec 3, 2011 08:15 PM
90pioneer
16
May 15, 2011 09:26 PM
digger190
20
Oct 3, 2006 06:58 PM
gti
Nov 18, 2004 07:17 PM
MarkF250
Sep 27, 2003 10:38 AM
