welding truck frames
Old Jan 17, 2002 | 05:52 PM
ford_nut's Avatar
ford_nut
i was wondering if welding and boxing a truck frame poses any problems with heat distortion to the frame. i had several areas of rot along the frame rails and i i had to first cut it out with a torch and now im reinforcing/bolting/welding/boxing everything BEFORE i prime the frame. should i be concerned with frame integrity after all this painstaking work???? thanks! :-staun
Old Jan 18, 2002 | 12:20 AM
proeliator's Avatar
proeliator
[updated:LAST EDITED ON 18-Jan-02 AT 01:21 AM (EST)]You should always avoid welding on the frame, because it does soften the temper so to speak, but sometimes you can't avoid it. If you are boxing in your entire frame it doesn't matter, if you are only boxing in certain sections you could have stress problems down the road.
Old Jan 18, 2002 | 12:44 AM
Franklin2's Avatar
Franklin2
https://www.ford-trucks.com/dcforum/User_files/franklin2/3be9efd76bf42a3a.jpg
Old Jan 18, 2002 | 12:45 AM
jdbanks's Avatar
jdbanks
artscott61
Feb 11, 2021 05:30 PM
COWBOYBUCK
Jan 23, 2015 06:32 PM
jejch1214
21
Jul 10, 2014 11:25 AM
F100man
Apr 13, 2014 04:33 PM
ulev1st
Sep 15, 2013 03:02 PM
