My new predator dosent work!!!!!!!
Old Dec 8, 2005 | 08:31 PM
adam red 351's Avatar
adam red 351
Just got my predator from motorhaven and it dosent work. I plug it in to my truck and it says booting ford 7_3 and then it says (The aplication is missing or corrupt) you hit continue and it does the same thing? Whats wrong?
Is there a code for this or do they need to send me another one?
Thanks ADAM,
Old Dec 8, 2005 | 08:40 PM
johnny8's Avatar
johnny8
get on the phone to the boys at diablo... they'll tell you what's up... they guys at motorhaven are really good, but they don't make the predator, they only sell it... cut out the middle man if you want info, if you just want to return it for another one, call motorhaven... sorry for the hassles you're having... i'm sure you were looking forward to having some fun..!
Old Dec 8, 2005 | 08:45 PM
edub32's Avatar
edub32
Hmm do new Predators come pre-loaded with the update?? If they don't I'd try getting the new update (if you have the pc interface kit). If you don't have one and don't mind waiting a little bit, I'd send it back and Motorhaven. They will take care of everything.
Old Dec 8, 2005 | 09:50 PM
clintbonnie's Avatar
clintbonnie
Did you have the ignition key on? It should be on to after plugging it the unit..
Old Dec 12, 2005 | 01:14 PM
Oil-Pig's Avatar
Oil-Pig
So what did you end up doing?? I have the same problem
Old Dec 12, 2005 | 01:38 PM
arninetyes's Avatar
arninetyes
I don't have a Predator, so I don't know how it functions. But - if you have a problem, johnny8 is absolutely correct - call Diablo.
They sure don't want people thinking their products don't work!!
Old Dec 12, 2005 | 07:53 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
The great thing about the Predator is that it will tell you to turn the ignition key on/off. Because I've hooked it up both ways.
Old Dec 12, 2005 | 08:21 PM
perrybmw's Avatar
perrybmw
My predator did not work either, but it was because the stock program in the truck was not in tact. I bought my truck used and it already had a program installed. I had to have the truck re-flashed with the latest ford stock program before the predator would work.
It has to have the stock program in tact to use as a referance. If there is anything a miss with your stock program the predator will not work.
Hope this helps,
Perry
Old Dec 13, 2005 | 07:27 AM
Oil-Pig's Avatar
Oil-Pig
Then I wouldnt worry about us that are trying to get our programmers to work without waiting on hold for the next available tech support operator. And by the way it didn't work untill I reflashed it.
Anyone that has a predator that gives the message "operating system missing or corrupt" means that the flash upgrade didn't take and it needs to be reflashed by downloading the latest firmware flash and DS_downloader. and re-programming the programmer. Then it works great!!! at my 60 hp setting its night and day compared to stock!!!
Old Dec 13, 2005 | 05:03 PM
arninetyes's Avatar
arninetyes
I'll bet it took more time getting it reflashed than it did sitting on hold for tech support.
Of course, that is no consolation when you have to wait for tech support and THEN get it reflashed!! Yuck.
AllabouttheGM
Illinois Chapter
Aug 15, 2011 05:42 PM
adamzelazowski
Feb 24, 2009 12:40 PM
adambomb
S. California Chapter
Jun 9, 2008 07:07 PM
adam red 351
Alabama Chapter
Dec 30, 2007 05:29 AM
aph453
Jan 29, 2005 11:04 AM
