Help wiring offroad lights into fusebox
I currently have my offroad lights wired into the fuse box using an inline fuse. What has happened is that when the lights were on, the plastic housing unit on the inline fuse keeps melting.
What i want to do is run the power for the lights into the fuse box. This way i can eliminate the plastic housing for the fuse. How do i go about wiring power into the fuse box??
All the help is greatly appreciated!
Sure, run a line from the battery to the relay with a fuse in between. then continue on from the relay to the lights. From the toggle switch on the dash, if you only want to be able to use the lights with the key on, tap into an accessory wire, if tou want to be able to use them all the time tap into a +12v constant source. This low current signal is going to flow through the switch when you flip it, and activate the coil in the relay which will directlly connect your lights to +12v on the battery and make them light.
You should need about a 25-30 amp relay, and you should be using about 8 gauge wire if your lights are all the way up on the roof, 10 if there on the front of the truck, just make sure either way to weatherproof all your exposed wiring because when on, those lights pull a lot of juice.
Firekite
1999 to 2016 Super Duty
09-01-2017 11:07 AM
Rusty_S
05-17-2016 12:14 PM
