Which way to turn hubs?
Old 12-08-2005, 10:32 AM
RShaips's Avatar
RShaips
RShaips is offline
I have a 2000 EX that is having the typical hub problems. My hubs have the letters wore off. Which way is lock and auto? I think that auto is clockwise but I am not sure. I have already had them off once and cleaned and got them working again, but now 3 months later they will not unlock the front end. By the way these are the worst piece of junk hubs I have ever used, and I have had 4 x 4s for 30 years. I will replace them with manual hubs, if I decide to keep this truck for a while. Thanks
Old 12-09-2005, 06:08 AM
RACERX7775's Avatar
RACERX7775
RACERX7775 is offline
get the warn premiums. they work the best. all you have to do is plug the vacuum lines. at least your hubs turn. mine are not supposed to turn. until i get the warns, it one hub fails on my X, i am screwed. no manual over ride for my hubs.
Old 12-09-2005, 07:04 AM
bluerage's Avatar
bluerage
bluerage is offline
I switched to the warn preminums, but was wondering what if the vacuum lines were not plugged?
Old 12-11-2005, 01:31 AM
RACERX7775's Avatar
RACERX7775
you will have a vacuum leak. engine wont run correctly, couple other things could happen. better just plug the lines. its extremely easy.
Raise
22
03-26-2017 12:27 AM
johnhammond
02-17-2017 05:42 AM
dhag911
12-12-2013 03:00 AM
boggerted
03-08-2007 05:58 PM
Spirit615
Offroad & 4x4
02-08-2005 02:41 PM
Quick Reply: Which way to turn hubs?
