Fuel filter Question
Old Dec 7, 2005 | 07:41 PM
TEEJAY's Avatar
TEEJAY
Cool Fuel filter Question
Is this possible? I changed a starter and battery on my fathers truck along with the fuel filter. After the new fuel filter and starter, the truck ran great for about a half hour, then it sputtered to a stop. The battery died trying to restart it over and over. After a few minutes it started again and ran fine to get me home. After pulling in the driveway and installing the new battery and EGR valve(there was a check engine code a few months back), the truck will not start! It will run when I spray starting fluid through it for a few minutes, but then dies.
Is it possible I got a bad filter? Did I put it in backwards? Did it clog up that quick (the old one was nasty!) Is it frozen? I'm at a loss!
The truck is a 90 F-150 with a 302 automatic
Thanks
TeeJay
Old Dec 7, 2005 | 08:50 PM
quicklook2's Avatar
quicklook2
try reseting the fuel shutoff switch.
check fuel relay and fuel relay fuse.
Old Dec 7, 2005 | 10:27 PM
TEEJAY's Avatar
TEEJAY
I hear the fuel pump cycle when I turn the key, so I don't think it is anything with the pump. I'm going to get a new filter and hope that works.
Old Dec 8, 2005 | 08:50 AM
whiteyfordzx5's Avatar
whiteyfordzx5
check to make sure you put the filter in the correct way and that the lines are nice and tight on it.
Mike
Bill97
23
Jan 13, 2012 10:07 AM
P1ckup Man
19
Jan 15, 2010 10:23 AM
Eric_F250
15
Dec 24, 2007 01:43 AM
TEEJAY
1997 - 2003 F150
Feb 17, 2006 11:33 PM
yankeechamps
Sep 24, 2002 02:59 PM
