Sponsored by: Real Truck
Funny things happening PLEASE help!
Old Dec 7, 2005 | 02:50 PM
psu927's Avatar
psu927
^^^ was just going to say what the last guy said, Don't get mad at me for saying that, just want to cover everything.
Old Dec 7, 2005 | 03:04 PM
jim henderson's Avatar
jim henderson
Might be dirty battery terminals. Several cars I have owned looked like they had clean terminals but there was some kind of dark smooth coating on the inside of the battery lugs. The lugs on the battery and cables need to be bright and shiney where they make contact with each other.
The typical symptoms when this happens are, the car gets hard to start in cold weather, the instruments start to act wacky, the lights are dim, and the door beeper and horns sometimes makes a sound like they are strangling. The battery can be in top shape and test fine, but the current isn't getting thru the terminals.
The fix is essentially free and easy, if you have a good battery terminal brush, I actually use one that is more like a big reamer, works great but got to be careful not to remove too much metal. On some cars that dark corrosion is almost like a plastic coating and requires some serious brushing to remove. Had to get the reamer exactly because of this reason. This seems to happen every few years, especially in cold wet climates(I never had this problem in SoCal, but several times in Oregon), so your truck may have enough time on the battery to have this problem.
Good Luck,
Jim Henderson
Old Dec 7, 2005 | 04:01 PM
FortyFords's Avatar
FortyFords
I guess some of us can't read,I'm in that crowd also.
But somewhere back in his post it says he tried another battery from another Car doesn't it?.
Rich
Old Dec 7, 2005 | 05:17 PM
Big Orn's Avatar
Big Orn
Rich
LOL! Yea, Rich, it's bad when you get old and acquire all those little quirks that go along with it...like SAS (Short Attention Span) and CRS (Can't Remember Squat)
Old Dec 7, 2005 | 06:48 PM
captchas's Avatar
captchas
Guest
hay we are not that far over the hill just yet. so what if i have crs and sas, i can still rebuild a flathead 8
Old Dec 7, 2005 | 07:14 PM
FortyFords's Avatar
FortyFords
I hear ya Mr Big , I fit right in
Rich
Yea but it just takes a lot longer! HMMMM !
that could be a good thing !
Rich
Old Dec 7, 2005 | 09:10 PM
jtmt72's Avatar
jtmt72
Well guys much thanks to all that have given their thought and idea on the problem. Now for the end of the story I turned GREEN[/U] when i found the problem. There was a single terminal block on the driver side fender under the hood that is feed by a battery cable and on the other side of the terminal two power cables go from there to feed the fuse block. Well after about 2 mins of looking at things found this battery cable so corroded and (GREEN[/U][/I][U]) that it was makinging just enough contact to drive me nuts. After a quick repair of putting a new lug on the cable and cleaning the other lug and post...WALLA everything is back to normal. I made sure to better protect that terminal conection against that problem again.
Many Thanks Guys for your help.
Jerry
Old Dec 7, 2005 | 09:16 PM
EnviroCon's Avatar
EnviroCon
Glad it's solved. Don't forget to put the fuses back into the remote start and anything else you may have disabled.
Old Dec 7, 2005 | 09:27 PM
captchas's Avatar
captchas
Guest
Rich
yep! is that not the great part. lack of sensation it does take longer to build that motor up.
Old Dec 8, 2005 | 06:28 AM
FortyFords's Avatar
FortyFords
Jerry,glad we could help in someway.
Rich
Charlie too funny man! motors running !!!!!!!!!!!!
Old Dec 8, 2005 | 07:28 AM
CmprSpecial's Avatar
CmprSpecial
Jerry
Glad to hear you have it fixed. Wish I was keeping up on things... As I was reading the posts, I was thinking you should check that connection on the drivers side fenderwell... It seems I was too late.
Very cool...
Old Dec 8, 2005 | 09:50 AM
gilkeson's Avatar
gilkeson
I have had the exact same experience with mine. I still have a problem with the blower running even after shutting down, but that is another thread. I have found that this generally happens when I have a bad battery. I replaced the battery and all was right with the world.
Although this time the ABS and SRS light have decided to stay on. I can't afford to drop it at a service centre and let the "look" for the problem so will have to go through the diagnosis process on my own.
I often hear a strange sound from inside the dash and wonder if the ground might be a problem.
HogTied
2004 - 2008 F150
19
Jul 14, 2022 10:49 PM
mikecox1
Aug 21, 2009 05:08 PM
cochran226
Sep 9, 2007 08:42 PM
PW01
Apr 2, 2007 10:21 AM
n6nfg
Nov 12, 2004 10:20 AM
