Deactivate clutch sensor
Old Dec 7, 2005 | 10:22 AM
cyeager1's Avatar
cyeager1
Got a 1988 Ford XLT Lariat. The clutch sensor to allow the truck to start has become a real problem.
Is there a way to quickly deactivate this?
Old Dec 7, 2005 | 11:12 AM
mudgepondexpress's Avatar
mudgepondexpress
You might want to check before you deactivate it. I don't know about the F series, but the Mustangs use that switch for control on the manual transmission models. When you step on the clutch, and/or the tranny is in neutral, the idle speed is decreased to conserve fuel, prevent overrun. When the tranny is in gear and/or the clutch is engaged, the idle is increased to overcome the drag of the tranny.
Kenny
Old Dec 7, 2005 | 11:14 AM
Machman's Avatar
Machman
remove the switch and leave the plunger in while it is plugged into the harness and tape it up out of the way.
Old Dec 7, 2005 | 03:38 PM
natewoz's Avatar
natewoz
You may also have issues starting the truck without it, since the clutch switch is typically in the started control circuit.
Old Dec 7, 2005 | 04:19 PM
ATC_250SX's Avatar
ATC_250SX
you could just jump it with a wire, unplug it, and run a jumper wire across it, just dont leave it in gear and start it withough pushing in the clutch! im pretty sure its just a starter safety nothing more.
CaptainIPSC
Jun 29, 2012 03:02 PM
expedite mike
Nov 30, 2010 10:11 AM
gearloose1
Apr 11, 2010 12:07 PM
termitedh3
May 27, 2007 10:34 AM
johnsdiesel
29
Oct 26, 2005 04:57 PM
