drive line angles
Old Dec 7, 2005 | 09:52 AM
78bigbronco's Avatar
78bigbronco
drive line angles
I read in another post that if you have a u-joint then your angles should be matched on each end of your driveshaft and only with a cv joint should you try to adjust the rear pinion angle to be nearly zero. Is this true? And this might be really basic but what is the actual difference between a cv and u joint? My 78 bronco has 4 u joints in the rear driveshaft with one of those double ended pieces that I thought was called a double cardan joint or something like that? (not sure if I got that terminology down). I did have a slight problem breaking the rear-most joint multiple times and I thought I had extra spring wrap due to a couple broken leafs, but I think my angle might have a bit to do with it also. Best I can tell is it is at or slightly above zero with the driveshaft.
Old Dec 7, 2005 | 10:38 AM
ivanribic's Avatar
ivanribic
A double cardan and a CV are the same thing. With a single u-joint the speed of rotation surges more or less but the CV (double cardan) uses 2 u-joints and they balance that change in speed out between the two of them, hence they are called a constant velocity joint.
You are correct that for a driveline with a CV at the t-case you want a 0º angle at the pinion and for a regular driveline you'll want the angle of the pinion joint matched with the angle of the t-case. This will help balance out that speed surge that causes vibrations in the driveline. One thing you need to remember on that rear axle is even though the pinion angle may be at 0º when you're sitting still the pinion will tend to wind up when you're driving. Unless you have ladder bars to prevent this you'll want to point that pinion down a few degrees so when you give it throttle it will come back up to a neutral angle.
Hope that babbling made sense.
Old Dec 7, 2005 | 09:52 PM
pokerpuller's Avatar
pokerpuller
so if i ran the regular u-joint at the differential, and a cv joint at the transfer case, i would want my pinion parallel to the ground, or pointing right at the t-case?
Old Dec 7, 2005 | 10:11 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
technically it is called a double cardan joint....because it has two u-joints, a cv joint is whats found in the front of a fwd car..
most people call double cardan joints cv's so.....
itsbecause a cv is true to "constant velocity" while a double cardan joint slightly speeds up and slows down through it's rang eof motion...callthem wu tu want
Old Dec 8, 2005 | 05:08 AM
460's Avatar
460
Pointing at the t-case, or a degree down to allow for axle wrap.
Old Dec 8, 2005 | 09:14 AM
78bigbronco
Ok, that just made some lights click on. I know that was really basic stuff but I always wondered what velocity had to do with a joint and why constant had anything to do with it. So, with a bronc that has a double cardan joint at the xfer case and a single u joint at the diff then all you have to worry about is that the pinion angle at the diff is just slightly below zero.
Old Dec 8, 2005 | 12:47 PM
ivanribic's Avatar
ivanribic
You got it.
Old Dec 8, 2005 | 06:00 PM
pokerpuller
so pinion angle is the angle between the pinion and the driveshaft?
-kit
Old Dec 8, 2005 | 06:15 PM
ivanribic's Avatar
ivanribic
That is correct. It is not relative to the angle of the pinion from the ground, only in relation to the driveshaft.
Old Dec 8, 2005 | 07:38 PM
pokerpuller
thanks so much. i understand a lot of stuff way better now.
-kit
73 ford guy
Offroad & 4x4
13
Oct 27, 2008 12:10 AM
466bogger
Offroad & 4x4
24
Mar 30, 2008 06:26 PM
Papadawg
Nov 13, 2007 08:50 AM
mako171
1978 - 1996 Big Bronco
Oct 9, 2006 06:34 AM
he race me
Apr 2, 2004 11:21 AM
