Glow plug heater not working?
Old Dec 6, 2005 | 06:57 PM
CFenton1982's Avatar
CFenton1982
I plug in the extension chord everynight before work and in the morning before start up, she takes forever to turn over. I've heard that a glow plug heater should be ready @ all times when plugged in. When I turn my ignition on I still get a 'wait to start' light that stays on quite a long time. Any diagnostic's that you can think of?
Old Dec 6, 2005 | 10:36 PM
Ed Willmott's Avatar
Ed Willmott
Are you confusing Glow plugs with the block heater? They are two different things.
Test your glow plug relay to be sure it is functioning then test your glow plugs themselves. This will tell you if glow plug system is working , which is responsible for initiating the combustion sequence upon start up.
Your block heater is what you plug in. This warms up the engine oil so that at startup, it will turn over easier and warm up to operating temp quicker.
Your glow plugs are not powered by the extension cord in any way.
Search this forum for testing procedures.
Also, post your signature (click user cp) so we know what truck you have to give you more specific answers.
Then, after people on this board have helped you solve your problem, and saved you hundreds of dollars compared to a "Stealership visit", consider spending $15 to support this site. It has paid for itself 100 fold for me in less than a year. 12 months ago I bought my first diesel, and this site has been invaluable!
Old Dec 7, 2005 | 04:17 PM
CFenton1982
Thanks for the advice. I made a mistake with my previous post. It is the block heater, and I am quite sure that it is not working properly! I will do some research to test the situation. Thanks.
Charlie
Old Dec 7, 2005 | 05:52 PM
Clint40's Avatar
Clint40
Charlie I just fixed mine tonight. I did a continuity test and got nothing , I then went to the block heater above the oil filter and unplugged it. I did the same test on the two prongs at the heater unit and did have continuity there, so the wire was bad. I called the dealer and it was 61.80 to replace the cord. So I hooked all back up did the same teat and nothing so then I went just beyond the plug end that is near my fog lamps and pierced the black coating and did a continuty test again it worked ( has to hooked to the heater to work too). So basically my plug end was bad. I spliced a new end on and saved 60.00 and I am in business.
chewyjackson
28
Mar 12, 2013 01:25 PM
XPD77
6.7L Power Stroke Diesel
Sep 27, 2012 08:41 PM
vfelix702
Jan 11, 2011 08:00 PM
Pwnm30rdi3
Dec 1, 2010 06:33 PM
Dan Taylor
Dec 6, 2009 06:32 PM
