overdrive type ?
Old Dec 6, 2005 | 10:16 AM
jav409's Avatar
jav409
overdrive type ?
The local Wrecking yard has a stand alone overdrive unit ( .27 under ) in a motor home in the yard. it is clean and looks to be in good shape. the price is right. Their is however somthing neither of us ( the yard guy ) or me can figure out. the shift in and out looks to be mech on a lever but their is a hose that runs to a canister under the hood ( motor and most other stuff is gone ) it doesnt look like a air hose. any one ever seen anything like this ? and of so what is the hose for? This would be a perfict overdrive for my 66 F100 if it would work. Solve the mystery hose and be forever in my gratitude
Old Dec 6, 2005 | 10:42 AM
The SnoMan's Avatar
The SnoMan
Likey a vent line to when to a remote filter
Old Dec 6, 2005 | 12:51 PM
jav409's Avatar
jav409
So this line could be pluged and the unit filled to level ? if so It would work for me.
Old Dec 6, 2005 | 01:05 PM
The SnoMan's Avatar
The SnoMan
You cannot plug the vent, it can cause seal to leak/rupture when unit gets hot and air expands in it. It had to have a vent somewhere.
Old Dec 6, 2005 | 02:48 PM
tjc transport's Avatar
tjc transport
i ain't rite
that is most likely a gear vendors od unit .it is mechanicaly controled by a cable, and the hose is connected to a vacuum canister for passing gear.
Old Dec 6, 2005 | 03:25 PM
jav409's Avatar
jav409
Thanks , so I would need to pickup a Vacuum canister and run it off of engine manifold vacum ? is this an older Unit? mostly the ones I see actually attach to the back of the trany, this one has yoaks at both ends. so the input would go to my C6 and the output to the rear axle. And down shift would be controled by vacuum? or some kind of vacuum switch ?
Old Dec 6, 2005 | 03:37 PM
The SnoMan's Avatar
The SnoMan
Unless it is hooked to a actuaotor on the outside of the case, it is still lilkely just a vent line.
Old Dec 6, 2005 | 04:49 PM
tjc transport
i ain't rite
yup. the older units from the 50's and 60's were remote mount cable activated, and used vacuum to downshift. a few different cars that i know of and have seen in use are packard, studabaker, jeep, and ford.
usually they use vacuum to engage, and when you remove vacuum, (floor it) it will downshift to direct drive. once vacuum is restored, you ease off the throttle and it upshifts again.
they work pretty good as long as you have a good vacuum source. a motor with low vacuum, like one with a big cam will have problems running one of these units.
vidaliaman
Feb 27, 2016 03:30 PM
mjunk1
Jan 29, 2013 04:41 AM
black water
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jul 5, 2010 05:53 PM
E250HDSuperVan
Jun 1, 2009 02:53 PM
jav409
Sep 4, 2004 02:57 AM
