screws stuck
Old Dec 6, 2005 | 07:04 AM
ripcurl94's Avatar
ripcurl94
screws stuck
I was taking the advice of some of the smart people here..(which i really do appreciate) and going to replace my TPS.. only one problem.. the two screws that hold it in .. will not budge.. i turned a 10 minute job .. into 1 hr and 1/2 of pure frusteration.. and still didn't get the sensor replaced. does anyone have any tricks to getting screws out.?? thanks
Old Dec 6, 2005 | 07:53 AM
FortyFords's Avatar
FortyFords
put a little pb blaster on them.
Rich
Old Dec 6, 2005 | 08:05 AM
ripcurl94's Avatar
ripcurl94
stripped them out..
I am afraid i stripped them out.. i used some plyers to try to get them loose and i got one.. to move.. but not very much.. maybe they were frozen.. it was 13 degree's outside...
pb blaster.. ok
Old Dec 6, 2005 | 08:08 AM
ranger88a's Avatar
ranger88a
I know this will sound stupid, but put talcum powder on your phillips screwdriver end. It makes it bite and hold. Valve grind compound works the best though.
Old Dec 6, 2005 | 08:10 AM
ilbigmike's Avatar
ilbigmike
Re: screws suck
try the pb blaster and if you can get behind them...tap with small hammer or 1/4" drive ratchet to loosen the corrosion up and glop on more blaster to lift crud out....good luck!
Old Dec 6, 2005 | 08:24 AM
ripcurl94's Avatar
ripcurl94
screws stuck
yeah.. thanks for the suggestions. i am afraid that i am beyond the point of screwdriver.. i mean.. the screws. are shot.. i am unable to get to the back of the screw.. this is the TPS so the screws are internal.. i think i am just SOL!
Old Dec 6, 2005 | 08:30 AM
ranger88a's Avatar
ranger88a
Just for future reference, the screws are loctited in from the factory.
Old Dec 6, 2005 | 08:36 AM
ripcurl94's Avatar
ripcurl94
i believe that!
Old Dec 6, 2005 | 09:15 AM
FortyFords's Avatar
FortyFords
When things are locktited try alittle heat gun to warm the the screw up alittle first.
We run into this alot repair snowmobiles.It seems to soften the locktite.
Rich
Old Dec 6, 2005 | 10:48 AM
ripcurl94's Avatar
ripcurl94
maybe an easyout??
http://www.crustyquinns.com/tech/easyout.html
anybody know if this might help.. these screws.. are so tight..
Old Dec 6, 2005 | 11:13 AM
Gil Chesterton's Avatar
Gil Chesterton
I have used these before and they work just fine. You need to get the drill hole centered properly and use the correct size bit/easy-out. I find them more difficult to use on smaller screws than larger bolts (less material to work with). A good set of these is not cheap as they are super-hardened steel.
I use a T-bar from my tap and die set to twist the easy-outs so I get even torque around the stripped bolt/screw.
Good luck!
Old Dec 6, 2005 | 09:39 PM
ripcurl94's Avatar
ripcurl94
TPS fix
Hey i was able to get the screws out.. replaced the TPS .. and SO far my trans is perfect.. the noise and hard shift from 3-2 is gone.. thanks everyone! $23.00 and 2 hr but it was WORTH it.
Old Dec 7, 2005 | 10:36 AM
Gil Chesterton
How did you get them out?
Old Dec 7, 2005 | 10:46 AM
ripcurl94's Avatar
ripcurl94
I was able to get one screw loose with pliers. took about 30 minutes .. i had to move it about 1/4 of a turn each time. but once i got one screw lose. i drilled the top of the screw out and was able to pull the sensor over the rest of the screw.. then since there was about 1/2 inch of screw left. i gentle unscrewed it with the pliers.. and replaced the sensor and bolts..and took her for a test drive..
WestyNaut92
Jan 21, 2017 11:58 PM
larrypellerin
May 2, 2016 07:17 PM
mudrat025
Feb 5, 2016 08:50 PM
steel120
Aug 28, 2008 01:45 PM
weavemaster
Nov 22, 2004 07:31 AM
