No Power
Old Dec 5, 2005 | 10:20 PM
meierotto's Avatar
meierotto
No Power
My 1986 Ford F-250 has a 5.0 EFI. It has lost its power and cuts out and hesitates when i am climbing hills and trying to go about 65. I have checked fuel pressuer and ran 2 cans of Sea-Foam through it but it still does the same thing. what could it be thanks.
Old Dec 5, 2005 | 11:08 PM
fordborn's Avatar
fordborn
Thread moved to " 221, 260, 289, 5.0/302, 5.8/351W V8" tech forum. Should find more responses to your question here.
Welcome to Ford Truck Enthusiasts. In order to make it easier to navigate please read the following: Forum Guidelines
Inside certain forum's there could be a Read First: thread or threads attached to the top.
Please read these threads before posting.
In Addition to the Tech Forums there are State/Province Chapters that bring local members together for meets, events and just plain fun.
Once again...Welcome to the FTE Family
Old Dec 6, 2005 | 08:53 AM
TigerDan's Avatar
TigerDan
Have you pulled the codes? Not all fault codes will trigger the CEL (Check Engine Light) and that's always a good place to start. There are several ways to do it. You can take the vehicle to a parts store such as Autozone who will check it for free in the nopes that you'll buy any needed parts from them, you can buy a code scanner for about 30 bucks to check it yourself, or there are alternate methods that you can use at home that don't require the use of a scanner. One involves using an analog-type multi-meter and there's another that uses a paperclip and you count the blinks of the CEL for your codes.
These methods are described in detail here:
http://fordfuelinjection.com/?p=13
Get the codes and if there are any then we can go from there.
Although, you might simply need to clean the throttle body and do a general tune-up. Plugs, cap/rotor, wires, filters. How long has it been since any/all of these were changed?
llljllollnlll
1978 - 1996 Big Bronco
Feb 11, 2013 07:02 AM
Joeceno
Feb 24, 2012 04:50 PM
Big_Dom
Apr 13, 2010 10:07 AM
EXPLORER GUY
Jul 9, 2007 11:00 AM
fujimo
Nov 30, 2000 10:42 PM
