Timing Sweet Spot
Old Dec 5, 2005 | 05:37 AM
ImNotFreud's Avatar
ImNotFreud
Timing Sweet Spot
I have a 302 Installed in a 1977 F-100. Also has 670 double Pumper Carb.Performance intake. Dual Exhaust. Mustang 3 Speed. I installed a Cam with the following Specs.
Adv Dur----260-260
Dur @ .050 .212-212
Valve Lift .447-.447
Lobe Sep 110.0
Looking for the timing Sweet Spot. I have started from one end of the Spectrum to the other and still seem to get pinging upon acceleration. Any help and suggestions are appreciated.....Thanks...
Old Dec 5, 2005 | 10:33 AM
Blurry94's Avatar
Blurry94
Premium gas will allow you to run more timing, and reduce detonation.
Old Dec 5, 2005 | 10:52 AM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Dec 5, 2005 | 12:40 PM
Kemicalburns's Avatar
Kemicalburns
10*btdc with vac advanced off would be a good starting point.
Old Dec 6, 2005 | 07:02 PM
F-150Guy's Avatar
F-150Guy
I just rebuilt my 302 with an Rv cam..it has similiar specs to yours, at first i ran it at 10 degrees...but it sounded like a diesel it pinged so much, then tried 8 degrees, still pinged. I took it down to 6, and it runs great with no pinging, my gas mileage improved as well. Check the box that your cam came in..is there a sticker on it with the specs? mine actually told me where i should set the timing
Gater180
Mar 10, 2016 05:51 AM
Gater180
Mar 8, 2016 08:56 PM
miashley150
Mar 24, 2013 06:59 PM
eriksf250
Mar 19, 2009 09:49 PM
Dr.B
Apr 23, 2007 06:00 PM
