73-79 Crewcab
Old May 27, 2006 | 08:29 PM
  #46
ottoparts's Avatar
ottoparts
73-79 crewcab
I have a 1976 F350 Factory longbox 2WD that I am selling. It has a factory 460, factory A/C, delay wipers, and extra's. If interested let me know. Ottous1@yahoo.com. Thanks
Old May 30, 2006 | 07:56 AM
  #47
johaner78's Avatar
johaner78
annafd1, what year is your crew? I'm afraid your hitch rep doesn't know what he is talking about. I can honestly say that mine is a 1978 F250 Crew 4x4, shortbox. I have verified this using the VIN and all the VIN decoding materials I can find, build dates, etc. that mine is a '78 with a 37" frame. The two VIN numbers stamped into the frame also match the cab/body VIN number. This truck is all original. The front of the frame is 34" but it widens to 37" just at the back of the cab back to the end of the frame. So, my frame would need a 37" hitch installed. My truck also has dual tank setup. This I can confirm is factory - I have the original factory build sheet for this truck. Seems odd that everyone else that has 78 crews only have one tank (midship) with 2 doors in truck bed. Weird. I guess I must be a lucky one the way mine was built.
johaner78
Old May 30, 2006 | 09:29 PM
  #48
annafd1's Avatar
annafd1
my crew is a 79 2x4 when i posted about the hitch before the replies i got matched what the rep had told me. my crew is 3/4 ton short box.
Old May 31, 2006 | 07:34 AM
  #49
johaner78's Avatar
johaner78
annafd1, the difference must be 2x4 vs. 4x4 in frame size then.
Old Jun 6, 2006 | 08:46 AM
  #50
johaner78's Avatar
johaner78
1978 Crew cab Brake Cable length
Can anyone provide me with the correct length (or at least darn close) for the front and the two rear brake cables for a 1978 Crew cab 4x4??? Mine are completely shot and missing parts of them and noone has ever made a set (not even Inline Tube). I need to get them some measurements so they can build me a set. Thanks!
Eric
johaner78
Old Jun 28, 2006 | 03:11 PM
  #51
parajj's Avatar
parajj
2 tanks
i have a1978 f250 crew cab 4x4 it to has dual tanks loking to put in a diesel engine any info let me know
Originally Posted by johaner78
78crewcabjohn, i have a 78 crew also. Does yours have 2 fuel tanks? I see that yours only has one fuel filler location. Mine has two tanks. Anybody ever seen a short box with 2 fuel filler doors?
Old Jun 29, 2006 | 07:14 AM
  #52
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Jul 28, 2006 | 12:31 PM
  #53
daddyo4's Avatar
daddyo4
VIN numbers on frame?
Daddy04, just another thought about your frame - are you sure it is a 78 frame???? Do the VIN numbers on the frame match the VIN on the body? Both VIN numbers stamped in my frame match the body VIN number and everything correlates to a 1978 truck. Just a thought.
Where do I find the VIN on the fame?
Old Jul 28, 2006 | 02:03 PM
  #54
johaner78's Avatar
johaner78
Daddy04, you will find the VIN stamped into the right frame rail on the top side one being near the right front cab mount and the other one further down the frame rail to the rear which will be under the cab. My box and cab are off the frame and frame was sandblasted so was real easy to find them. This number should match the VIN of the truck cab, etc.
Old Jul 29, 2006 | 08:37 AM
  #55
twobitranch's Avatar
twobitranch
Smile
I am restoring a 1978 4wd and I need to find the chrome trim piece that fits between the front and back doors. It is about 4" long and I have been looking everywhere. If anyone has one on a parts truck they would part with let me know.
Old Jul 31, 2006 | 07:26 PM
  #56
daddyo4's Avatar
daddyo4
Johaner78, I will look to see what I can find for your brake cables. Thanks for the info on the VIN #. I have a frame that I am going to build my truck on, but the cab mounts are all wallered out from the bushings holding moisture against them. I am welding steel plates over the holes, but I dont know what size hole to drill for the cab mounting bolts. Are your holes still good?
Old Aug 1, 2006 | 06:20 PM
  #57
bushman's Avatar
bushman
I know it is a long way from Ohio, but I know where there is a 1 ton crewcab for sale.
Bushman
Old Aug 2, 2006 | 12:42 AM
  #58
tjay460's Avatar
tjay460
johaner78 check out this thread for brake cable info.
https://www.ford-trucks.com/forums/s...11#post2738411
I ordered the tru-torque cables from partsamerica.com. These are the rear cables that go from the center cable to the wheels. Fit like a glove and work nicely. I think they had the other cable as well. Hope this helps.
Old Aug 2, 2006 | 12:50 AM
  #59
tjay460's Avatar
tjay460
My '78 F250 4x4 short box crew cab has 2 filler doors as well as 2 tanks, and it ain't afraid to use them.
Old Aug 2, 2006 | 12:25 PM
  #60
johaner78's Avatar
johaner78
tjay460 and others - thanks for the replies concerning brake cables for crew cabs. I had some made by Inline Tube. I have a parts book on CDROM and got the lengths from that and had Inline Tube make them. They look like the originals. I should have posted this earlier. Thanks anyway!
tjay460 - did your crew come with factory air or did you add it? I'm thinking about adding factory air to my Custom cab? Am i nuts for doing that?
