73-79 Crewcab
Old Dec 20, 2005 | 07:18 PM
  #31
blueknightcrew's Avatar
blueknightcrew
Let me know what your looking for and maybe I can help you out.
Ron
Old Dec 21, 2005 | 07:00 AM
  #32
sfourdoor's Avatar
sfourdoor
I'd like to see a picture of that "6 door/8ft bed" I've often thought of taking an extended cab and adding it to a crewcab, anyone ever seen that done?
Old Dec 21, 2005 | 07:48 AM
  #33
blueknightcrew
I've seen a couple of them done that way but haven't done it myself. makes a great looking rig.
Old Dec 21, 2005 | 06:04 PM
  #34
makeityours's Avatar
makeityours
The truck isn`t finished yet but working steady on it.I used two crew cabs.Lookin for rear door panels(prefer black but any color will do),couple of rear doors if price is right.If I can figure out how to post photos(new to forum , sorry)I`ll post photos of the project so far and photo I found of crew cab with extended added with 8 foot bed.Photo was on the internet somewhere.
Old Dec 21, 2005 | 10:02 PM
  #35
Menroid's Avatar
Menroid
I saw one on ebay once, I will see if I can dig up the pic I kept.
Old May 17, 2006 | 04:35 PM
  #36
daddyo4's Avatar
daddyo4
I know I'm 6 months late...
Originally Posted by johaner78
78crewcabjohn, i have a 78 crew also. Does yours have 2 fuel tanks? I see that yours only has one fuel filler location. Mine has two tanks. Anybody ever seen a short box with 2 fuel filler doors?
I've got a '78 f-250 crewcab stortbed with 2 fuel doors, but get this- only one tank! The rear door is inoperable' and seems to have a stud on the back of the door with a nut on it which prevents the door from opening. I have found no reason to suspect that the bed is not the original, but I can find no evidence that the truck ever had the second tank! There is a piece of angle iron rivited to the frame rails (from one side to the other) right in the middle of where the fuel tank should be. This truck (even though its a '78) has the narrow frame, like a pre-771/2. I know that the 78-79 (wide) frame held the tank between the frame rails, which would not be possible on this frame.
Old May 17, 2006 | 04:41 PM
  #37
daddyo4's Avatar
daddyo4
crewcab parts?
Originally Posted by blueknightcrew
Hey I currently have 8 73-79 crewcabs and I'm trying to sell a couple of them if your interested. Give me a shout. They did make shortboxes with the dual fuel doors, I've got a few. I'm putting one on my 76 project.
Do you still have crewcab parts to get rid of? If so, where are you located?
Old May 17, 2006 | 06:01 PM
  #38
Mil1ion's Avatar
Mil1ion
Quote: I have found no reason to suspect that the bed is not the original, but I can find no evidence that the truck ever had the second tank
Daddy04,
Check on the right side of the heater controls for a dual tank switch .
Old May 18, 2006 | 07:54 PM
  #39
daddyo4's Avatar
daddyo4
The switch is not there, but the dash is not the original. There is no fuel selector valve under the truck, but wasnt the rear tank the primary? Seems odd that the truck would have a mid-ship tank, and no aft axle tank. Unless there was something else back there. What kind of spare tire carrier were the highboys equiped with?
Old May 19, 2006 | 10:11 PM
  #40
annafd1's Avatar
annafd1
there was a guy close to me that had two for sale he placed an ad in the clasified section in feb or march. do not know anything about them
Old May 19, 2006 | 10:17 PM
  #41
annafd1's Avatar
annafd1
my 79 crew cab has two doors in the short bed and only one tank located under the cab. i need a fuel tank for the truck
Old May 25, 2006 | 07:19 PM
  #42
daddyo4's Avatar
daddyo4
How wide is your frame at the rear of the truck? A '79 should be the 37" frame but so should my '78,and its the 34" frame. Does the rear fuel door open?
Old May 26, 2006 | 07:38 AM
  #43
johaner78's Avatar
johaner78
daddy04, my '78 crew has the 37" wide rear frame, dual tanks, two fuel filler doors in the box (both work) and the fuel tank selector switch on the dash. Looks all factory to me as I have this thing totally tore down to bare frame and nothing on this truck has ever been apart. The truck was undercoated sometime in it's life (probably when new as there is undercoating on the bottom side of the firewall) and both fuel tanks have undercoating sprayed on them. I believe mine came from Canada equiped with the dual tank setup.
Old May 26, 2006 | 07:40 AM
  #44
johaner78's Avatar
johaner78
Daddy04, just another thought about your frame - are you sure it is a 78 frame???? Do the VIN numbers on the frame match the VIN on the body? Both VIN numbers stamped in my frame match the body VIN number and everything correlates to a 1978 truck. Just a thought.
Old May 26, 2006 | 12:38 PM
  #45
annafd1's Avatar
annafd1
my frame is 34in i found out when i bought a hitch for a 73-79 ford and it was too wide. i called the hitch manufacturer and told the rep that i had bought a hitch for a 79 crewcab and before i said anything else he said that it was the wrong hitch i needed one 34in . he said the 3/4 ton crew is on the 1ton frame. also my bed has 2doors on the bed with only the front used
