Cluster Issues
Old Dec 5, 2005 | 06:44 AM
degdawgs's Avatar
degdawgs
Cluster Issues
On my 1980 F100, I have no dash lights, which makes it hard to drive in the rain and dark. The fuel gauge also quit working. How do I remove my Windshield wiper and light ***** in order to remove the panel. The Hayes manual says to remove the clibs right behind the *****, but I do not see them and can't figure out how to remove them.
Old Dec 5, 2005 | 08:37 AM
Holmesuser01's Avatar
Holmesuser01
My '83 has a tiny clip on the base of the ****. I use a tiny flat screwdriver to press the clip toward me as I gently pull the ****. Its the same for the headlight switch.
Did all the lights die at once?
Do you have a set of gauges? Do the other gauges work? (not including the batt gauge)
Fords are notorious for the fuel guage system problems. Mine has 2 tanks, and 2 bad fuel sender units in the tanks.
Your truck has a fuse for the instrument lighting. Has someone been improving your wiring?
Let us know.
Old Dec 5, 2005 | 08:43 AM
63redtudor's Avatar
63redtudor
They're usually on the underside of the *****. Look there & you'll see a small slot (1/8" or so). Shine a light into there & you'll see the clips.
If you need parts for your gauge, I have my old one still. It came out of my '84 & may not be totally compatable with your '80, but you're welcome to it. Send me a PM.
Edwin
Old Dec 5, 2005 | 12:09 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Edwin
Everything in the cluster should be interchangeable except for the printed circut on the back.
It could also be the Light switch itself.
Indecl
Apr 8, 2012 05:30 PM
xc4jokestomper
May 21, 2011 09:02 PM
ken 01
2004 - 2008 F150
Jan 15, 2011 11:22 PM
berry1234
Mar 22, 2009 08:53 AM
johnsmart
Aug 26, 2003 12:12 PM
