For the headlight switch you have to reach up under the dash and find a little button on the side of the switch. Push on it while pulling out on the ****. You may have to kind of push and release the button a couple of times. Then, carefull push the shaft back in untill the head lights and then the parking lights go out. Pull it back out before it latches again.
The wipes **** has a little clip inside the back of the ****.Sometimes they just pull off but you may need to push on the clip with a screwdriver.
It seems a lot of people think you just press the button and pull.
Causing frustration & Rage.
The proper method is to Pull the switch **** OUT to the headlights on position > THEN depress the button and pull it out.
Mil1ion, I need the windshield ****. I've seen them at the parts stores, but I was looking for one that looks like the original (to match the headlight ****). I guess I could just replace both of them with something different.
Gosh UglyF250, those are some UGLY *****, ha ha!! Just kidding........I don't even think your truck is ugly. How can it be, it's a Ford! Actually I think your ***** are pretty cool, and I may just copy your idea!!
I saw oodles of ***** last week when I was
cruising the junkyards for parts. Some of them
were even in extremely good (ie one notch away from
new-uncirculated) condition...
Other than that, try ****** *********. I'm using
asterisks because it's not clear to me what the board
policy is regarding mentioning ford restoration
parts companies, but think of the initials "DC" along
with the east coast...
