When was the 1st year for the 5spAuto in the 7.3
the last year for the 4r100 and the first year of the 5r110 (torqueshift) was in 2003. all 7.3 automatics that year had the 4r100. however, the 6.0 was released in that year also, but it had the 5r110. i have never seen a 6.0 with 4 speed, or a 7.3 with torqueshift. but that would be awesome!if you consider locking and unlocking the torque converter in the same gear two gears, then you could well enough call the 4r100 a 7 speed automatic.
so, is the torqueshift a true 5-speed auto that also uses the t/c lockup feature..? i'll be honest, i don't know anything about that tranny, but i have had one guy i met tell me the tranny that was in his 2004 was junk, and the dealership could not fix it, although they tried 5 times.... ford ended up buying that truck back from him... i'm sure i could learn more about this tranny on the 6.0 forum... i was just curious...
Originally Posted by strokin_it7.3
the torqueshift is actually a 6 speed, but uses 5 gears selectively. 5th gear is considered top gear in tow/haul mode, while in tow/haul off, 6th gear is like a second overdrive. i believe 4th is direct drive.
interesting.... have you heard any reports on this tranny...? is it any good..? i had a couple of guys tell me they really like it, but that one guy told me his was a complete piece of junk...
we have one of those puppies in our 2004 6.0. it was replaced with a factory remanned one, at about 17,000 miles. when you put it in reverse and tried to accelerate, it would just shudder and grind. alot of the parts were fried. however, the transmission is one awesome slushbox.
tomorrow morning, we are taking delivery on a 2006 f-250 SC SB. powerstroke with torqueshift automatic. its a work truck for me
man..! you are just one lucky son of a gun...! i wish someone would buy me a worktruck like that..!
the accountant said that we had to buy something big, or else Uncle Sam would take it. our income to expenses ratio put us in a class where we would have to pay alot more taxes than if we would have bought something. we are putting the plow on our red f-350 on that, (the 3/4 ton front is "too light"), so the v-blade we were going to put on my truck is now going on the red 350.
Here are the gear ratios:
1st - 3.11:1
2nd - 2.2:1
3rd - 1.54:1
4th - 1.09:1
5th - 1:1
6th - 0.71:1
Fourth is the gear ratio that is rarely used because it is so close to fifth. In a normal upshift, in or out of tow/haul, it shifts 1-2-3-5-6. In tow haul the shifts are later, but it uses the same gears.
All 7.3Ls had the four speed auto, and all 6.0Ls have the 5 (6) speed auto.
Installing a 5 speed TorqShift in a 7.3L would be quite a job. The bellhousings are not the same, and the length is not the same. But those are the easy parts to fix. Making a computer that can run the TorqShift behind a 7.3L would be very, very expensive.
When (not if) my tranny finally goes, I will probably switch to a 6-speed manual. I've never liked automatics.
Still, by putting in a trans temp gauge, a proper shift kit, a trans cooler, and a bypass external filter, you can increase its life and make the 4r100 more tolerable.
Wrong.
1st - 3.11:1
2nd - 2.2:1
3rd - 1.54:1
4th - 1.09:1
5th - 1:1
6th - 0.71:1
1st - 3.11:1
2nd - 2.2:1
3rd - 1.54:1
4th - 1.09:1
5th - 1:1
6th - 0.71:1
oh and Johnny8, here are pics of the truck, just picked it up an hour ago.
https://www.ford-trucks.com/forums/s...d.php?t=436565
