Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Air Hose
Old Dec 4, 2005 | 12:11 PM
AndrewHR's Avatar
AndrewHR
Air Hose
I was wondering if there is a maximum length of Air Hose you can use before the pressure drop/air flow decrease becomes a problem. I want to use 3/8 ID (10 mm) hose. Can i use 200 feet or should i stick to shorter lenghts? Any help would be appreciated
Old Dec 4, 2005 | 01:00 PM
petes79f150's Avatar
petes79f150
Depends on several things- how big is the compressor, what is it being used for (impact or air ratchet vs. occasional shot-term use), and how often are you going to roll up your hose? Several shorter lengths are easier to handle than one long one. The biggest factor is your compressor's capacity (volume). How often are you going to need the whole 200 feet?
Old Dec 4, 2005 | 02:40 PM
AndrewHR's Avatar
AndrewHR
Its a 2hp compresser. I will only use 200ft occasionally for low consumption tools. I was thinking of getting 2 x 100 ft hoses and joining them when needed
Old Dec 4, 2005 | 08:47 PM
Torque1st's Avatar
Torque1st
Posting Legend
Sorry I do not have figures for 3/8" ID line.
Pressure drop per 25 feet of air hose, proportional for longer or shorter lengths:
1/2" ID
Initial pressure: 80PSI/100PSI
20 SCFM: 0.9/0.7PSI
30 SCFM: 2.8/2.3PSI
40 SCFM: 6.0/8.4PSI
3/4" ID
20 SCFM: 0.2/0.2PSI
30 SCFM: 0.5/0.4PSI
40 SCFM: 0.8/0.6PSI
-From the trade standards adopted by the Compressed Air Institute
It would be best to pick up one length of 1/2" line and another of 3/8" line. Use the larger line off the tank first.
Old Dec 5, 2005 | 12:28 AM
fixnair's Avatar
fixnair
Smile
The deciding factor in this issue is the amount of air the tool consumes. The air in the hose, when the tool is off, is static. When you operate the tool then the hose has to conduct enough air to keep up with the tool. If it cannot supply enough volumn of air then the pressure drops. An easy way to find this out is to install a temporary air pressure gauge right at the tool handle. Operate the tool and observe the gauge. If it drops below the minimum pressure required by the tool then increase the pressure switch, if you can, to compensate. if you cannot compensate with increasing pressure then you will have to go to a larger hose. Another way to resolve this issue is to install another receiver out at the work area, connected by the long hose to your air compressor, and then use a shorter hose to connect your tool to the auxilliary receiver. This will provide power untill the aux. receiver is consumed.
Old Dec 6, 2005 | 01:29 AM
Torque1st's Avatar
Torque1st
Posting Legend
Fixnair that remote receiver method works well. I built one of the remote receiver systems a number of years ago for a friend. They do give a user brief periods of full power operation in between waiting for the receiver to recharge. It can make the difference on a stubborn fastener.
Old Dec 7, 2005 | 06:28 AM
AndrewHR's Avatar
AndrewHR
Thanks for the responses. I appreciate it. I think i will take the third option and buy some wheels for the compressor and move it when I need a longer length hose.
Andrew
gman97005
Air Intakes, Air Filters & Ram Air
Jun 6, 2016 11:09 PM
Pete Kildow
Large Truck
Nov 5, 2013 10:19 PM
olblue77
Dec 5, 2012 08:14 PM
1990350
Apr 17, 2009 09:38 PM
rednekf350
Garage & Workshop
Apr 2, 2006 02:48 PM
