Yesterday, I installed a set of Eibach 2" Rear Drop Shackles. I'll have to say... Two inches is alot more than I thought! My truck, which once suffered from that factory "high-tail", now sits perfectly level at all angles. Plus, the install was simple and straight-forward.
The only problem I ran into was the bed/fender structuring bar. It had to be unbolted from the bed support crossrail and moved to the side, then reconnected at the conclusion of the installation. Other than that, it's was as simple as cutting cake!
