Cam ID'd!
Old Dec 4, 2005 | 02:35 AM
Polkat's Avatar
Polkat
Cam ID'd!
Hi! I finally figured out that cam I was trying to ID a few weeks ago. It's the M-6250-M50 as we figured it might be. This is not a very radical cam, made mostly for torque at lower rpm's. Still, I have a use for it. Would you care to offer a suggestion (or anyone else reading this) as to what springs to use?
Thanks.
Old Dec 4, 2005 | 03:13 AM
TigerDan's Avatar
TigerDan
I've been snooping around, and while I can find plenty of references to that cam I can't find diddley on valve spring recommendations. I'm go out on a limb here and say that since it's a low to mid-range cam you can probably use stock valve springs with it. Certainly stock 351W Cobra "R" valve springs anyway...! (I know, that helps a bunch...!)
Old Dec 4, 2005 | 02:19 PM
Polkat's Avatar
Polkat
Yea, I couldn't find anything either. Thanks for looking! I have a bunch of stock springs, but they are old. Guess I'll try to search out the R springs. Also, I'm putting this in a 302 (I know about the firing order) so I'm guessing the 302 pushrods will be fine. Thanks again.
tyler70f250
Jul 18, 2013 04:27 PM
jakedevore
Jan 27, 2012 02:43 PM
BaronVonAutomatc
Jan 26, 2011 08:12 PM
77swb
May 9, 2008 07:39 AM
JimNolan
Aug 29, 2005 12:27 PM
