How to Identify Axles?
Old Dec 3, 2005 | 05:26 PM
SmashFascism's Avatar
SmashFascism
I have a 1979 for pickup and was wondering what axles are under it. Its a F-150 with the 351M 400 and a C6. how do you identify a Dana Axle? Also Does this come with a mated or devorced transfer case? I havent had a chance to look.
Thanks in advance, Matt
Old Dec 3, 2005 | 05:49 PM
seventyseven250's Avatar
seventyseven250
Check the door tag
Take a look at the door tag. it will have a code that identifies the axle that the truck started out with.
Old Dec 3, 2005 | 06:08 PM
plowpusher's Avatar
plowpusher
79 f150 4x4 will have a married transfercase 9 inch rear dana 44 front
Old Dec 4, 2005 | 02:00 PM
roan65's Avatar
roan65
how do you tell by looking at the axle. I think I found a couple crew cabs with dana 60 in front and dana 80 in rear.
Old Dec 4, 2005 | 03:41 PM
Slow's Avatar
Slow
They are probably 70 rears in the CC. On the diff housing on the front off to the side you'll find a '44' or '60' or '70' cast into it. This is near where the casting meets the axle tube. That's the best way to identify them. Go under there with a wire brush and clean up the flat parts of the housing and you'll see it.
After you see a few though you can tell just by looking at them. The front hubs on the 60s are a lot bigger than the 44HDs. The dana 70 rear that I have has 1 1/8" lug nuts.
Beware however that the older front dana 60s are low pinion and if you try to put it in your 79 with a married t-case you might have a hard time with drive shaft angles. A 78-79 CC could have a high pinion dana 60.
The pre-77 dana 60s have slightly weaker axle shafts than the 78-79s, but are still stronger than the 44HDs and have larger u-joints so they are still a better axle. I've seen some folks here say that they are weaker but everything I have 3 pre-77 dana 60s plus a 79 44HD and looking at them along with some research on the axles I'm sure they are still stronger than the 44HD.
Old Dec 4, 2005 | 06:41 PM
plowpusher's Avatar
plowpusher
All crew cab 4x4 had a dana 60 front stock there should be a 60 cast in the webbing to the right of the cover
Old Dec 4, 2005 | 07:16 PM
75crewcab's Avatar
75crewcab
I have seen a 78 cc that had a 44hd in front it maybe because it had a 300 ci engine
jrodimus
Apr 3, 2010 07:52 PM
ssquints999
Jul 1, 2009 03:22 PM
classicfordfreak
Feb 8, 2006 03:30 PM
matco_design001
Jan 10, 2003 12:19 PM
EdC351M
Sep 19, 2002 12:50 PM
