1978 - 1996 Big Bronco
which code reader
Old Mar 23, 2008 | 11:18 AM
80351's Avatar
80351
Sorry can't answer that question.
Old Mar 23, 2008 | 02:06 PM
muckypaws's Avatar
muckypaws
The Lamp on the shifter stalk indicates overdrive cancel mode activated (lamp on), electronic pressure control circuit shorted or monitored sensor failure (lamp flashing).
You need to pull the codes using a code reader, multimeter or indicator light - see fordfuelinjection.com for info on how to do it with the latter two - but its much easier with a $40 code reader.
That will tell you which sensor is faulty etc.
Old Mar 23, 2008 | 02:27 PM
80351's Avatar
80351
Muckypaws, sounds like you have dogs and it seems you have about the same links I do. Are you an FSB member?
Old Mar 24, 2008 | 06:38 AM
Tarpon1's Avatar
Tarpon1
MPaws-- I need an OBDII..., I'll try the Bay
Old Mar 24, 2008 | 08:47 AM
muckypaws's Avatar
muckypaws
Are you sure about that? The only OBDII bronco is the 96. Everything before that was OBDI.
80351, No I don't have dogs, Muckypaws is a nickname I picked up from friends as I used to spend a lot of time playing in the mud back in my Land Rover days. Not a FSB member, looked a few times but always found my answers here so kinda stuck with it.
Old Mar 24, 2008 | 12:32 PM
Tarpon1's Avatar
Tarpon1
Yes, I own a 1996 XLT FSB- So, OBDII
Old Mar 24, 2008 | 12:36 PM
muckypaws's Avatar
muckypaws
oh sorry, we were talking about a 89 initially. you confused me! lol No worries. OBDII is a little more tricky to diagnose, but I believe the connectors and interface is more standardised that OBDI so a code reader will be more generic.
fordbozo
Jul 11, 2012 09:34 AM
tooldad
2004 - 2008 F150
Feb 9, 2011 07:14 PM
bkuuz1
Jan 11, 2010 12:02 AM
Dan Robertson
Escape & Escape Hybrid
Dec 13, 2009 10:16 PM
93F250
Garage & Workshop
Aug 17, 2008 11:14 PM
