AHHH!! SO EXSPENSIVE
Brake Shoes, Front (pr.) $26.63 Raybestos 265RR
Brake Hose, Front (pr.) $37.55 Raymold 4536531
Wheel Cyl., Front (rt.) $21.30 Raymold 2018291
Wheel Cyl., Front (l.) $21.30 Raymold 2018290
Brake Spring Kit, Front $13.25 OP H7040
Power Brake Booster $18.11 Salvaged 67 Ranger
Pedal Bracket, Pedals $12.78 Salvaged 67 Ranger
Pedal Bushings $2.92 Motormite 74016
Master Cyl. (Power Brake) $21.19 Cardone 10-1388
T fittings, vacuum hoses $18.65
Wheel Cyl., rt rear $12.45 Raymold 2017507
Wheel Cyl., l rear $12.45 Raymold 2017508
Hardware, rear $6.72 Raymold 507071
Brake shoes, Rear (pr.) $35.22 Raybestos 263RR
Brake Hose, Rear $39.30 Raybestos BH36606
Reman. Booster $97.63
Rear Hardware Kit $2.86 Raybestos H1457-2
I did the lines, too, you'll pay about 80 cents a foot for bulk steel brake line, and you'll need the fittings, too. You can do everything pedal to shoes for less than Midass is quoting you for one end. This is something you should consider doing yourself.
67 F250
68 F100 390 Edelbrock Performer heads,roller tip rockers,crane cam, Edelbock intake, Edelbrock 750
69 F350
If you did what he's gonna do, you'd spend just about as much.
I had to put new drums on my 66 F-250. It made an improvment, but not like the Disk Brakes of my 73 F-250.
Maybe you can swap to Disk brakes with a Donor truck?
