Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Questions about "PB BLASTER" penetrant
Old Dec 2, 2005 | 01:33 PM
Greywolf's Avatar
Greywolf
I've used it some, and it resembles aircraft turboshaft lubricationg oil in color and the way it spreads.
Evidently it is approved by FOMOCO, and I wondered if anyone else besides me has used it...
-Website reference:
http://www.pbblaster.com
They have some related products (at least one of them you will immediately recognise), and if FTE does not already have them as sponsors, consider this as a potential sponsor alert, otay?
Old Dec 2, 2005 | 01:46 PM
cigarxtc's Avatar
cigarxtc
I was introduced to it by a good ol Ford truck boy back in my military days. I was wrestling with some rusty parts that wouldn't budge and he sprayed PB BLaster all over it and in no time the pieces came apart. Since then I have always had a can of it handy. It sits next to the WD-40. Did you ever see the advertisement of how it is so strong you can melt a styrofoam cup with it? I wondered if it was true and tested that--and it worked. It ate the bottom of that styrofoam in a matter of hours and turned it into goop.
Old Dec 2, 2005 | 01:54 PM
jbullfrog's Avatar
jbullfrog
Gasoline will melt a styrafoam cup as you our into it.... Now that's fast!
Old Dec 2, 2005 | 02:12 PM
OSin86's Avatar
OSin86
I use it if I can't find liquid wrench, the stuff smells like moth *****. LOL
Old Dec 2, 2005 | 02:32 PM
great90wt's Avatar
great90wt
I aways keep a couple of big cans of PB'Blaster in the garage. Great stuff.
Old Dec 2, 2005 | 03:01 PM
FortyFords's Avatar
FortyFords
Use it all the time, Buy it buy the case.
Great stuff better than LW,
Rich
Old Dec 2, 2005 | 03:37 PM
tjc transport's Avatar
tjc transport
i ain't rite
i use it with heat. makes it even better. heat up whatever you are trying to loosen, then spray it on. let it cool off, and off it comes.
i used it on a hitch that was frozen into a reciever after being left in for 10 years. hooked the ball to a loaded tandem dump truck (65,000 lbs.) with a chain, and started tugging. moved the dump truck 4 ft.. went back to the shop, and heated the reciever up, then sprayed the pb in all over the place with the little tube.10 min later, went back out to the tandem, and thought the chain slipped off, cause i just went across the yard. got out to see the hitch laying on the ground.
Old Dec 2, 2005 | 03:51 PM
Mr.Ford 351W's Avatar
Mr.Ford 351W
I used, right now i have 3 cans of PB Blaster, at murrays, they sell it forr 2.99
reg price is 3.99, here is murrays ads:
http://www.murraysdiscount.com/inter...ge=7&store=409
Old Dec 2, 2005 | 10:34 PM
ivanribic's Avatar
ivanribic
I had good luck with it when I disassembled my suspension. I ran out and have been too lazy to get any more. I like the smell of it.
Old Dec 2, 2005 | 11:20 PM
Oval_obsessed's Avatar
Oval_obsessed
I love that stuff. I used to use WD40 but PB Blaster is so much better. I also like the smell.
Old Dec 3, 2005 | 12:31 AM
Ford_Six's Avatar
Ford_Six
That's the third best penetrant I've found- the only better spray is used at the Chrysler dealerships, you can't buy it. The top though is the red dye for checking pipe welds. This stuff clings and climbs, is thinner than naptha, and is such a good penetrant you have to put the bottle in a baggie to keep from getting it everywhere.
Old Dec 3, 2005 | 11:51 AM
Greywolf's Avatar
Greywolf
I seem to recall a discussion or two on WD-40 where it was pretty well defined as a substance originally intended to displace water, and which had very little if any lubricational properties. It's also one heck of a bait scent for catfishing...
PBB is a definite penetrant, intended for that purpose specifically.
TURBOSHAFT LUBRICANT, AIRCRAFT - 01/EA I can no longer get. But it's enough to loosen up a baptist minister in a Georgetown cat-house...
One drop on your jeans will spread out to four inches across, and it stays in there.
Old Dec 3, 2005 | 06:54 PM
Torque1st's Avatar
Torque1st
Posting Legend
Many items that even PB blaster failed on have been successfully loosened by the "Candle Trick" listed in the FAQ thread here. The candle trick is quick too. You don't have to wait days for it to work.
PB blaster, WD, and other lube/penetrants/etc have been discussed in many other threads here.
Old Dec 3, 2005 | 07:10 PM
jgc2521's Avatar
jgc2521
well i've been usin it for years. it's the only thing I use. And the styrofoam thing worked for me in about 5 minutes, nothin left of that cup.
Old Dec 3, 2005 | 08:04 PM
captchas's Avatar
captchas
Guest
pb blaster here also. i keep a few cans around for marine work and old cars or trucks
