zf6 maintenance
Old Dec 2, 2005 | 02:49 AM
akfalconer's Avatar
akfalconer
zf6 maintenance
I'm looking into changing my 6 speed tranny fluid soon.The faq's articles only
cover the auto,any pointers?
Old Dec 2, 2005 | 06:51 AM
Kwikkordead's Avatar
Kwikkordead
No gotcha's at all. It's simply a gear box. Change it out with Mercon 4 ATF and you are good to go. The transfer case (if you have one) is separate from the transmission itself and needs to be changed as well. Again use Mercon 4.
Old Dec 2, 2005 | 12:33 PM
ColtM4's Avatar
ColtM4
I think Kwik meant Mercon, as I'm not aware of any Mercon 4. In any event, ZF has an extensive list of approved lubricants for that transmission. All I can say is I switched to Mobil 1 ATF and it shifted smoother. When I drained the first batch of Mobil 1 ATF out of it, the fluid looked brand new compared to the brownish red factory fill that came out.
Old Dec 2, 2005 | 10:51 PM
akfalconer's Avatar
akfalconer
Thank's guys,how much mobil,(or mercon)should I get?
Old Dec 2, 2005 | 11:03 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
It will hold 6 quarts of Mercon rated ATF. I am also a user of synthetic ATF. In addition to the smoother shifts ColtM4 mentioned, it is also quieter. The "gear rollover" noise, as it's called, is less pronounced.
Mark Kovalsky
Large Truck
Mar 2, 2016 09:03 PM
snakedoc
May 20, 2015 09:55 AM
Jacob84Ford
15
Jan 16, 2015 07:52 PM
Mrfun2fly
General Diesel Discussion
15
Oct 30, 2014 09:23 AM
Adam0331
29
Aug 20, 2009 10:29 AM
