mazda 5speed
Old Dec 1, 2005 | 09:06 PM
bluebones's Avatar
bluebones
mazda 5speed
Hey guys,my mazda tranny is toast after over 200,000 in my 89 f150 4x4.A friend told me where a 91 frame and running gear is with the 5speed.will that tranny and transfer case fit my 89?
Old Dec 3, 2005 | 08:53 PM
Kista20's Avatar
Kista20
yep it's all the same stuff. Usually I don't see those lasting that long and I'm suprised that yours did. Mine has 111,000 and just recently replaced the shifter bushings because they were shot and I also fixed the leaking plugs while I was in there, so I'm hoping that will make it last a lot longer till I can get a zf.
Old Dec 4, 2005 | 01:35 AM
cubman61's Avatar
cubman61
I had over 260,000 on my 88 when I sold it. Never had any trouble with it. Changed the fluid and always checked it to make sure it was full.
Old Dec 6, 2005 | 02:28 AM
phoneman91's Avatar
phoneman91
Keeping the M5R2 full and taking care of the three leaking rubber plugs seem to be the secret to making these transmissions last--just from reading the threads on the website.
Old Dec 6, 2005 | 06:58 AM
bluebones's Avatar
bluebones
Thanks for the reply guys.I just picked up the tranny and t-case,everything seems nice and tight.Gonna replace those troublesome rubber plugs before she goes back in.
Old Dec 6, 2005 | 09:02 PM
Kista20's Avatar
Kista20
make sure to put some rtv around them and let it setup overnight. I also read somewhere on here that some people have used 5/8" freeze plugs. The only reason you need those plugs is so you can get the shifter rails in and out but if I'm going to goto that much trouble I'd probabally just get another tranny anyways.
Also make sure before you pull the top cover off that the transmission is in neutral, it will make the job a whole lot easier. The directions on here says to leave it in first but it's just wrong and needs to be updated. When I was doing mine I left it in first gear but when you put the shifter back in it doesn't line up and will not shift and I messed with it all evening untill the next day I somehow thought what if I put everything into neutral so I slid the synchronizers back one and put the shifter into neutral and everything went back together like a piece of cake.
Old Dec 7, 2005 | 05:52 AM
bluebones's Avatar
bluebones
Thanks Kista20
Old Dec 9, 2005 | 08:15 AM
smudge's Avatar
smudge
I have a mazda 5-speed in a 98 f150 4.6 v8 4x4 is this the same trans as the older f150???
biglou96
15
Mar 7, 2017 05:32 PM
Kapusta
Dec 8, 2016 01:07 PM
TXKaiser
Mar 22, 2007 11:15 PM
tampabandit
Apr 3, 2004 12:00 PM
bubbaredneck
15
Feb 13, 2002 07:57 PM
