Clutch problems.......need help fast
Old Dec 9, 2005 | 01:44 AM
19903024x4's Avatar
19903024x4
OK.....i can press the clutch pedal to the floor.....no resistance and extremly hard to shift. sometimes grinds a little when i do manage to get it to shift. Does it sound like my clutch has finaly died?..its 2 degrees here and its almost 2am....so i really wasnt fond of the idea of climbing under it right now to have a look at anything.
Old Dec 9, 2005 | 08:28 AM
classicfordfreak's Avatar
classicfordfreak
It sounds to me like you could have a slave cylinder or clutch master cylinder problem. Does the clutch have alot of miles on it?
Old Dec 9, 2005 | 09:06 AM
19903024x4's Avatar
19903024x4
102k miles on all of it...i just check the master and its empty...cant see where any fluid might have run to anywhere.....is it possible since its been no more than 10 degrees the past few days that it might just be froze and stuck?....or do we think it sprung a leak and drained?
Old Dec 9, 2005 | 10:43 AM
bob arrington's Avatar
bob arrington
up here ive seen a few slaves , that when it gets cold and the rubber cups in them are marginal , or 'high milage' , they shrink ,and allow fliud to leak out . I just did one that did it in a dodge school bus with hydro clutch, couldnt see where it was leaking and when i filled it and blead it worked fine for about three days. The only fix is to put a kit in the slave cylinder, which not only improved the 'feel of the clutch , but hasnt 'leaked' since, Bob
Old Dec 9, 2005 | 11:24 AM
19903024x4's Avatar
19903024x4
i'm thinking thats what it is....since its now 14 degrees....up from 3 this morning and theres snow on the ground i'm gona have it taken to a shop since i currently dont have anywhere to work on it where its warm. It couldnt wait till next month when i move to my new house with the moster garadg thats heated.......guess i made it mad
