94 computer 97 motor
Old Dec 1, 2005 | 05:04 PM
k460's Avatar
k460
it there an adapter to make to wiring harnesses match from a 97 OBD II motor to a 94 OBD I computer
Old Dec 1, 2005 | 05:26 PM
Rockledge's Avatar
Rockledge
A '94 computer won't work properly in a '97.
OBD-II is more sophisticated than OBD-I and has more emission system monitors.
Old Dec 1, 2005 | 05:29 PM
k460's Avatar
k460
so the computer will have to be swapped out? How hard is that?
Old Dec 1, 2005 | 05:37 PM
RangerPilot's Avatar
RangerPilot
Not bad, if you are good with wiring. My suggestion would be to pull everything out of the '97 and put it in the '94. The more you can use, the better. It's a slow process, you'll need a shop manual of some sorts.
Old Dec 1, 2005 | 05:40 PM
Rockledge's Avatar
Rockledge
Should be simple enough, unplug the wire harness (held on with a bolt). IIRC there are a couple screws or bolts that hold the PCM in place, take them off and and then pull the unit out.
Old Dec 1, 2005 | 07:14 PM
AlfredB1979's Avatar
AlfredB1979
Use only the BARE 97 engine and hope everything hooks up properly to the 94 harness. The 94 model, outside of Kali, won't have a crank position sensor. Just leave that missing piece unconnected on the 97 engine. If it's a 3.slow you're hooking up, you have to pop a distributor in place of the coil packs that came in for 95 model year. A 4.0L might be a relative no sweat swap since it's always had coil packs.
That is the only way to pull this off, by just using the bare engine.
After 95, Rangers used an electronic speedometer, deleting the cable, so that's just one issue (of many) you'd face crossing OBD1 and OBD2 together.
Old Dec 1, 2005 | 09:05 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
You're heading down a bad road, get the correct ECM for the 97.
Old Dec 1, 2005 | 09:07 PM
natebaker's Avatar
natebaker
Never mess with computers. Use the right one man, be more trouble than you'll want to get in to.
