94 Explorer suspension
Old Dec 1, 2005 | 12:33 PM
Jakevmi80's Avatar
Jakevmi80
My 94 explorer is getting very sloppy in turns, going over bumps and generally sounds very sqeeky in turns. THe shocks are only 4 years old. Any recommendation on improvements or upgrades to the suspension?
Old Dec 1, 2005 | 01:19 PM
mrshorty's Avatar
mrshorty
1st thing I'd do is make sure everything in the front suspension is tight (tie rods, ball joints, radius arm bushings, wheel bearings, etc.), make sure the tires are properly inflated, and that the alignment is on.
Old Dec 1, 2005 | 01:46 PM
LOTR-HAMMER's Avatar
LOTR-HAMMER
is the 94 same bearing set up as the 91. The 91's were notorious for the bearings loosening off because the bolts were only tight by compression. which failled over and over if not done right. maybe loose bearings but the bushings on 4 year old shocks could be warn as well
foust123
Dec 18, 2011 01:20 AM
mfp4073
1983 - 2012 Ranger & B-Series
Jan 10, 2011 02:43 PM
DKRoff
Oct 16, 2003 02:18 PM
nitro94
Apr 26, 2002 10:41 AM
calikid
Nov 25, 2001 08:15 PM
