On this chevy site it said this: Also available is a VORTEC 8100 V8 engine big block, it has more torque than a V8 and V10 gas engines from Ford or Dodge. It offers 340 horsepower @ 4200 rpm 455 lb ft of torque @ 3200 rpm.
They bearly even made a power gain from 325 hp and 447 foot pounds of torque
It features a powerful 42-volt lead-acid battery pack underneath the rear seat, an auxiliary starter-generator between the engine and the transmission, an electronic control module, and a regenerative braking system, which charges the battery while braking, and coasting.
With an auxiliary generator capability, the truck's generator can operate when the truck is parked without a key in the ignition. The hybrid Chevrolet Silverado and GMC Sierra pickups could power tools or appliances for up to 32 hours non-stop. This design shuts the engine down before the tank is emptied, leaving enough gas to drive to a station for refueling. All power supply circuits are protected by a ground fault detection system to prevent overloads and short circuits.
A compact electric motor that generates up to 14,000 watts of continuous electric power makes these pickup trucks more fuel-efficient
they better do some thing like that as dcx has talk of a v12 benz gas motor that they have out since the mid 90's in the works to replace the v10 they stopped useing. and it is one heck of a motor.
