marine 460 with DO0E heads/intake
official marine engines generally has more nickel in with the cast iron, to resist corrosion from sea water being circulated through the block and heads. Boats generally don't have radiators and such, they suck nice cold water from what they are floating on, making for a cooler engine overall even though the engines have to work much harder, and sustain higher RPMs than gas engines since there isn't a transmission (or a 2-speed), depending on the configuration.
Also, because boat engines rev higher, typically the heads and intake flow a bit better, valves are sometimes larger, but that depends on the casting and stuff like that.
I'd personally have no problem using marine heads on a truck, its been done before. In fact, the twin-turbo stroker I'm building is using "industrial" heads... which have the EFI Intake ports, but the slightly heavier duty casting of the marine heads, which enabled me to port the snot out of them. I removed TONS of material in the ports without any worry of breaking through the casting.
Parts are parts. If it fits, enjoy
IDIoit
18
12-08-2016 07:06 AM
itsnotanova
05-02-2011 06:51 PM
Fordication
02-15-2006 10:03 PM
jdadamsjr
08-14-2004 11:27 AM
