Electrical Nightmare
Old Nov 30, 2005 | 10:01 PM
Mil1ion's Avatar
Mil1ion
Okay !
But remember
Unfortunately It can happen with one bad start
Click >Vrooommm > Cough > Bang >< 45* off.
Old Dec 1, 2005 | 06:33 AM
SwOkcOffRoader's Avatar
SwOkcOffRoader
Originally Posted by goomba
By similar, Do you mean it was no spark in crank but had spark in run?
yes, i believe that was a problem, at least my symptoms were the same, i never actually did a voltage test, but if the engine didnt fire right off it would just turn and turn....it would also stick in the start position occasionally..maybe im way off base on this one and my problem was totally different, but looking back i beleive the symptoms were quite similar....
Old Dec 1, 2005 | 07:24 AM
KJKozak2's Avatar
KJKozak2
Some ford starters sit deeper in the hole than others, which is why the shims are available. I bought a new starter last year and it made a horrible noise once the engine started. Turns out the gear on the starter was rubbing the flywheel. I made a shim for it and it's been fine ever since. The difference is only about 1/8" or so and it's really hard to tell just by looking.
K.
Old Dec 1, 2005 | 12:44 PM
Mil1ion's Avatar
Mil1ion
You may also have a starter solenoid going bad.
Low power in a battery can cause solenoid lock up in start position.
bearhugger
Feb 1, 2012 11:42 PM
Jim88554
New Member Introductions
Mar 11, 2007 06:47 AM
uwdtbuds
Aerostar
Jan 3, 2007 10:39 PM
New Blue
May 14, 2003 08:08 AM
Jim_Banville
Jul 9, 2002 02:02 PM
