Dash Light ?
Old Nov 28, 2005 | 01:02 PM
jjfl99psd4x4's Avatar
jjfl99psd4x4
Dash Light ?
Anyone ever had to change a light bulb in the instrument cluster? The far left light bulb (fuel guage and volt meter) seems to have burned out. Truck is a 99 SuperCab 4x4
Also, What does the sensor in the airbox do? Mine was disconnected prior to me owning the truck. I noticed it when I scanned the codes and came up with the sensor error. Would this sensor change the performance of the truck in any way?
Thanks in advance for all the help.
Joe
Old Nov 28, 2005 | 07:36 PM
jjfl99psd4x4
Any Ideas????
Old Nov 28, 2005 | 07:43 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Heard the dash bulbs are kind of a pain....
The airbox sensor is the IAT (intake air temperature). It will have no effect on the engine's performance. It could alter how the high idle works when it's cold.
Old Nov 28, 2005 | 07:49 PM
jjfl99psd4x4
Thank You .... Living in south florida, I have never had my truck go to the high idle. How cold does it have to be for that to kick in???
When you say "kind of a pain" Do you know if I have to take the entire dash apart?? If so, then it is probably not worth it.
Old Nov 28, 2005 | 08:19 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
i believe the engine oil temperature has to be below 140*, and the ambient temperature to be less than 37* (measured at that sensor)
Old Nov 28, 2005 | 08:26 PM
cookie88's Avatar
cookie88
FTE Emeritus
Below 40F., and the oil below 155F. Not much chance of that down there...I wouldn't worry about it.
It's more of a hassle than a pain really. The dash panel pops right off once the stereo reciever is out, then there are just four screws holding the instrument cluster in. The transmission range indicator has a cuple of clips holding it in...and the wiring harness. The light themselves are the same little 1/4 turn bulbs Ford has always used. No biggie there.
Old Nov 29, 2005 | 08:10 AM
jjfl99psd4x4
Actually it was 43F at my house the other mornng....... Not quite there.
Old Nov 29, 2005 | 08:59 AM
Fordafied's Avatar
Fordafied
I took my dash off when I installed my propane arming switches. It is not hard to do. You just have to work it out slowly and unplug a few wires. On mine I had to unplug the ESOF and a few others I remember. The radio slid out with the dash easily and you have to unhook it also. Really not hard to do, you just have to be careful doing it, that's all.
Old Nov 29, 2005 | 09:11 AM
cangim's Avatar
cangim
Well I'm glad to here that the dash isn't all that bad, I want to change the face to a white backround, and put red bulbs in it to match my gauges. Does anyone know if simply putting red bulbs in will work or is there a filter on the gauge cluster that makes it green?
PaysonPSD
66
Dec 30, 2016 08:09 AM
briangelc
Mar 2, 2014 10:08 PM
joe blow
Jun 4, 2013 12:36 AM
joe blow
Dec 13, 2010 12:27 PM
Stacey
Nov 17, 2000 11:10 PM
