ect & timing
Old Nov 26, 2005 | 10:44 AM
camarokid81's Avatar
camarokid81
ect & timing
i have a question about the ect sensor on a 93 5.0. does the ect sensor have something to do with the ecm`s adjustment of ignition timing? if it was bad the timing could be off a little?
Old Nov 26, 2005 | 11:58 AM
Ford_Six's Avatar
Ford_Six
It only affect the timing indirectly, since that tells the computer when to go into closed loop and starts adjusting the timing. If that is not reading correctly, the engine will run rich or lean.
Old Nov 26, 2005 | 11:40 PM
Blurry94's Avatar
Blurry94
Coolant temps affect timing more than just open/closed loop conditions. If the coolant gets too warm, the PCM will pull timing.
